Reload this Page >
T-33 Shopping. Suggestions Please!
Old 08-07-2022, 05:57 PM
highhorse
highhorse's Avatar
Default T-33 Shopping. Suggestions Please!
Iím in the mood for a T-33 and hoping to benefit from othersí experiences. Iím open, size-wise for anything in the range from 90N-180N.
I donít mind paying more for quality and wish to avoid whatever may be out there which requires customer QC and/or engineering to make safe and reliable.
Which brands do you think I should run away from? Which should I run toward?
Thanks gentlemen for your inputs!
Don.
Old 08-08-2022, 04:06 AM
Springbok Flyer
Springbok Flyer's Avatar
Default Skymaster 1/5 scale T-33
Don,
For me, that is a very easy suggestion to make - the Skymaster 1/5th Scale T-33. Originally built mine in 2011 and fitted it with an AMT Pegasus HPe (17kg thrust). The only change since then has been my change-over to a PowerBox Core, from my original Futaba 18MZ.
Here is what drew me to it and has proven to pay off:
1. I trusted Anton and his team implicitly to give me the most fantastic after sales service and support - they have never disappointed.
2. The scale undercarriage including the scale oleos and wheels are so far ahead of the rest, it is amazing.
3. The scale surface detail is fantastic.
4. The airbrakes work perfectly.
5. The scale, opening canopy looks and works great.
6. SM was prepared to custom paint the T-33 for me, charging only the standard painted price.
7. The initial setup was a touch tail heavy, but easy to fine-tune quickly.with some excellent help from the late-great Bob Violet (I will be happy to share all my settings)..
8. The build quality is awesome and no stress cracking or undercarrige issues at all, since all my flying has been off grass, except for the occasional event on a hard surface.
After 11 years, she is still one of my favourites and performing and looking mint. There is not a single time that I take it for a fly and don't receive compliments and the usual question - what kit is that?
Regards,
JanR
ID:	2272123   Click image for larger version
ID:	2272124   Click image for larger version
Old 08-08-2022, 05:45 AM
sysiek
My Feedback: (176)
sysiek's Avatar
For me the feibao t-33 I have it for more than 10 years with the propane start k-170 and still flying strong
Old 08-08-2022, 07:59 AM
FlyJ
Neither of those airplanes scream "high quality" to me, and I've owned them both. Both require a bit of re-engineering to make them daily flyers. The SM was probably great for its day, but it's apparent that the kit hasn't received any updates since it's release 23 years ago. Both have 2nd rate pneumatic retracts with heavy wheels. On my SM I always had to fly inverted to retract the gear, even with 100lbs of pressure. The FB has a very hacky door setup that requires bolting a scissor link to the wing skin with 4x M2.5 screws on each side. Both have low quality paint work with paint streaks throughout. We had many thumb prints, orange peel, and chips on both of my FB and SM kits.
The one area where these airplanes shine however is their flight characteristics, both fly very well once properly setup. If you wanted high quality, I'd order one in white and paint it yourself and expect to rebuild several of the systems. The only alternative to the FB and SM is the Scale-Jets T-33. I think this is probably the highest quality T-33 you can get, but it's built very light and may not be a good choice for a daily flyer.
The following 2 users liked this post by FlyJ:
Halcyon66 (08-08-2022), sideshow (08-08-2022)
Old 08-09-2022, 05:52 AM
acw
Have you considered a BVM kit?
F-80 & T-33
Old 08-09-2022, 07:54 AM
highhorse
highhorse's Avatar
F-80 & T-33
I have seen their ad and of course will consider BVM, but the aim of this thread is to go beyond ads and dive into personal experiences. If you’ve assembled/flown the BVM unit then please do share your thoughts!
Old 08-09-2022, 11:56 AM
highhorse
highhorse's Avatar
Do you recall the dry weight? Thanks.
Old 08-09-2022, 12:47 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
My FB T33 was 63# at takeoff. Empty was about 55#.
Old 08-09-2022, 01:21 PM
highhorse
highhorse's Avatar
WOW that’s heavy!
Old 08-09-2022, 01:57 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
That's why I sold it. Too big/heavy for one guy to move around.
Old 08-10-2022, 10:08 AM
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by highhorse View Post
WOW thatís heavy!
The one I build was also 63 lbs with fuel and smokeÖ..
Old 08-10-2022, 02:12 PM
Springbok Flyer
My SM T-33 is 46lbs empty and 55lbs at take-off. Bear in mind that my AMT Pegasus is heavier than most other equivalent size turbines, so building it lighter will be easy.
JanR
Old 08-10-2022, 10:41 PM
Aquilon
Aquilon's Avatar
Hello,
My SM T-33 is 44 lbs empty (gen 1, without Airex).
Powered by K210G4, tuned at 190N, with 4,6 l fuel.
Flies perfectly, no issues with stock gear @ 8 bars.
Stťphane
Halcyon66 (08-10-2022)
Old 08-10-2022, 11:38 PM
Halcyon66
Fantastic looking airframe.
Regards,
Old 08-11-2022, 06:24 AM
jvaliensi
I saw a BVM F-80 at the field a month or so ago. It was Apollo Field. The owner told me he had not flown it or any other RC in five years.
The F-80 was the most beautiful jet I ever seen. He told me he bought it off the fellow that built it and it was a Top Gun model. I think it had an older P60 in it.
Anyways, he took off and put on one heck of a flight, I was impressed. That jet really screamed along and it was pretty heavy (22lbs+).
That would be my choice for a T-33 or F-80. However, the BVM kits are so expensive and need so much work to complete. I wish they made it available as a Gold Fly series.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
