Reload this Page >
Question about Jet-Tronic air filters
Old 08-16-2022, 07:23 AM
FenderBean
FenderBean's Avatar
Default Question about Jet-Tronic air filters
Question for the masses, when I got my big shipment of Jet-tronic air valves I also ordered some of their air filters. They are designed to keep the moisture out of your valves which can cause them to not function properly. If you have used these what has been your experience and how did you use them? I know most people use them when they add air but I think they are designed to go in your model. I was thinking about using them in my next build and just adding them inline on the fill ports to the air tanks but it can be a failure point. They have changeable filters with a lock system. Thanks
https://www.fb-rc.com/.../air-filter-for-the-air-valves
Old 08-17-2022, 03:35 PM
jvaliensi
If I had pneumatic retracts, I would look in to use dry nitrogen for the system. 20 cu.ft cylinders may be available at home depot.
Old 08-17-2022, 09:07 PM
Dave Wilshere
I’ve never used them, it’s just more joints!
I add one drop of silicon oil (buggy shock oil) to the air filler valve at the start of each flying day. This is blown into the system and keeps things lubed.
Been doing it for 20 years and have super reliable gear.
Old 08-18-2022, 03:31 AM
BarracudaHockey
BarracudaHockey's Avatar
Thats not a filter its a moisture trap
Old 08-18-2022, 04:37 AM
FenderBean
FenderBean's Avatar
yelp understand that, bad wording on my part but Jet-tronic calls them air filters for their air valves. They serve two functions moisture and keeping any thing out of the air valve.
Old 08-18-2022, 04:44 AM
BarracudaHockey
Ahh ok, that makes sense.
Old 08-18-2022, 05:30 AM
Auburn02
Auburn02's Avatar
As we discussed in Kentucky I'm not entirely sure how effective they actually are at trapping moisture, especially on the compressor side that's being used to fill systems in multiple models 15-20 times or more in a day. Perhaps in a single model it would not saturate nearly as quickly and be more helpful.
Old 08-18-2022, 06:47 AM
FenderBean
FenderBean's Avatar
yeah the ones on the compressor are essentially worthless but I was wondering about using it in the model application. Same results? guess I can try it on the next model, should have plenty of room .
Old 08-18-2022, 09:50 PM
David Gladwin
David Gladwin's Avatar
I ALWAYS have one in the delivery line of the compressor, never in the model. Certainly traps moisture as can be seen in the clear body ! Always assumed since it traps moisture it will also filter fine debris, seems to be the case !
Old 08-19-2022, 01:08 PM
FenderBean
FenderBean's Avatar
Even with one on my air compressor they always seem to still spit water out.
Old 08-19-2022, 01:44 PM
Auburn02
Auburn02's Avatar
Yep, my experience is the same. I have one on the delivery line of the compressor, and it certainly traps some that I see in the clear cylinder body of the trap itself. But I also have clear tubing on the output side of the trap and see plenty of moisture in there too.
