Jetcat P160 hot starting
My Feedback: (15)
Hello. I’ve got a temperamental Jetcat p160 it hot starts every time and cannot figure out what is causing it. Pulled motor apart to look for clogged injectors valves are not leaking changed parameters factory reset
After the initial start up it seems to idle fine and turns up wot I posted a video on Facebook Jetcat owners Rc u isn’t letting me post a video here
Is that a P-160RXI? Anyway, ... the main fuel valve may not be fully closing during previous shutdown. Are you closing the manual fuel shut off during refueling? Pre-RXIs sometimes occasionally had issues with the external main fuel valves too.
If it’s an old SE with everything turned off connect an air pump to the valves and check they hold over 100psi. You can hear the solenoid click, but it does not mean the valve is operating inside.
The following 2 users liked this post by Dave Wilshere:
patf (10-12-2022),
Springbok Flyer (10-03-2022)
My Feedback: (15)
P160 finally figured it out
Update. Thanks for all the help. Turns out after trying different parameters it still wouldn’t cooperate if I got the flames down then it wouldn’t ramp up. Turns out it doesn’t like diesel I put some fresh jet a in it and after it started diluting in the header tank it started running right Now it’s starting with no flames there’s a video of a guy testing the difference between jet a and diesel His first run was jet a no flames a few flashes like mine is doing now but with diesel a lot more flames
My Feedback: (41)
I gave several models to a friend as I need to get rid of them and he's a big Diesel guy. One had a JetCat P130RXi and it ran fine on Kerosene here at 2500' ASL but at his field elevation of 4500' ASL, it would start but not ramp up. Had the same issues with a JetCat P180RX; ran fine here at 2500' ASL on Kerosene but would not even start at 4500' ASL on Diesel. While he still needs to adjust the ramp curves, both engines started spooled up and ran well on Kerosene.
YMMV.....
