Reload this Page >
Trouble w/ Kamps Microturbine diffuser blade thickness
Old 03-27-2023, 07:23 PM
doctorklein
Default Trouble w/ Kamps Microturbine diffuser blade thickness
Kamps uses the diagram on page 84 of his book to detail the blades on the diffuser (adding that the vanes start with an angle of 21 degrees)
However the dimension that defined the thickness of the blade appears to be missing.
I believe this dimension could be the angle between the two sides of the blade or the distance between the two end points.
This dimension could also be a combination of the radius of the tapped holes in the blades and the amount of clearance between the M2 holes and the sides of the blade.
Any help determining the thickness of these blades would be very helpful! Or if you have a drawing of his diffuser that would be awesome!
I would post photos, but apparently I have to post 10 times before I'm allowed to post photos.
Best,
Doctor Klein
