Reload this Page >
The BOOMERANG SUPER ELAN.
Old 04-14-2023, 06:13 AM
Canadian Man
Canadian Man's Avatar
Default The BOOMERANG SUPER ELAN.
Saw this Last year at Kentucky Jets and was very excited by the BIGGEST Full Composite Boomerang!
We will be adding some cool equipment to this one!
flyalan61 (05-31-2023)
Old 04-14-2023, 06:15 AM
Canadian Man
Old 04-14-2023, 06:17 AM
Canadian Man
Specs from the Boomerang site.
Boomerang Super Elan – Twin Boom, Turbine Terror.
Sharing design DNA with the Boomerang Elan V2, the Super Elan is the larger counterpart to the Elan V2, spanning an impressive 116 inches tip to tip, and ready to light up the skies with 180 to 230 class turbine power. Powerful, fast, and well behaved in all regimes of flight, the super Elan is the perfect choice for pilots in search of stability and speed, punctuated with aerobatic flair in this gorgeous twin boom design.
Our first fully composite Boomerang Jet, the super Elan is both gorgeous and durable, offered in multiple high visibility liveries that are easy to track in the blue skies above.
Adding excellent value to this potent mix of speed and fun, Boomerang RC includes a complete set of electronic retracts for true aerodynamic perfection. Further this with electronic braking capability, landings are even easier, allowing for shorter distances on touchdown with active electronic braking.
Thanks to its generous wing area and large "Barndoor" flaps, low-speed control is unparalleled, making low-speed approaches a seamless affair. Pair the full span ailerons for rapid levels of aerobatic maneuverability, the Elan is both agile & nimble, offering excellent control in all regimes of flight.
Offering a generous access hatch for both the engine and equipment section for ease of accessibility, the super Elan comes equipped with a composite fuel tank, equating to extended flight time for this amazing machine. Fully fueled, the Elan is a short field performer, with grass field takeoffs at the ready.
Despite its size, the super Elan breaks down easily, allowing ease of transport in small vehicles and compact storage at home. Quick to assemble, the super Elan can be at the ready in short order, proving epic levels of flying once at the field!
With a fighter jet like appearance, the Elan lives up to its looks with performance to spare. Whether opting for an 180 sized turbine or a monster 230, the super Elan is destined to deliver.
Specifications:
Wingspan: 2946 mm ( 116 inch )
Length: 2900 mm ( 114 inch)
Empty Weight: 16 kg(35.3 Ibs)
Turbine: 180 – 230 Sized Turbine
Fuel Tank: 6.5-7L Liters (~236 Ounces)
Features:
- Incredible Levels of Low-Speed Control
- High Strength Composite Twin Boom Design
- Excellent Aerobatic Capability
- Durable High Strength Full Composite Design
- Included Electric Retracts w/ Electric Brakes
- Cavernous Access Hatch w/ Large Hardware Bay
- Large 236 Ounce Composite Fuel Tank for Extended Flight Times
- Composite Control Horns w/ Metal Ball Links
- High Strength 4mm Stainless Steel Turnbuckles
Included In the Box:
(1) Boomerang Super Elan Jet Kit
(1) 236 Ounce Composite Fuel Tank
(1) Complete Hardware Package
(1) Electric Retract Kit w/ Electric Brakes
Required for Flight:
(1) 9+ Channel Transmitter
(1) 9+ Channel Receiver
(1) 180 – 230 Sized Turbine
(9) Standard Sized Servos
Old 04-14-2023, 09:40 PM
Jannica
Is there any chans that this one will be available for purchase in Europe?
Jannica
Sweden
Old 04-17-2023, 08:18 AM
Canadian Man
Jannica
Sweden
Best thing to do is contact boomerang [email protected]
and see what can be done! [email protected] [email protected]
Jannica (04-17-2023)
Old 05-03-2023, 05:45 AM
Canadian Man
The Beast Begins!
Old 05-03-2023, 05:51 AM
Canadian Man
Don't Forget your LOCTITE!
Old 05-03-2023, 05:55 AM
Canadian Man
Photos are a bit erratic.
Horn gluing. Very nice to see hardwood hard points on all the horn mounts.
TABBIES!
TABBIE PREP
Open up the flap pin holes on both sides to get pin sitting tighter.
Doors already have layout complete for hinges. Very Nice!
Rudder Servo Mount. If no rubbers are used, you may have to install a washer.
Boom's have some serious connections to the main fuse. 2 x massive carbon tubes. Tabbie fastening and also top and bottom fastening.
Old 05-03-2023, 05:57 AM
Canadian Man
Wing Tabbies.
Main gear and door install. Very easy and nice layout!
Flap glued in plane and held tight with tape.
Flap movement. Could also reverse the horns but with stock/standard setup you can get massive movement no problem.
Stock Ball joints and rods are 4mm. Very nice and strong!
Old 05-03-2023, 06:00 AM
Canadian Man
Main side boom mount through tabbie.
main gear mounted with stock hardware. Nice big allan head wood screws x 6
Fron gear install. Simple and easy to line up.
Generally I use Powerbox wire for everything. Trying out a new aviation wire. Slightly heavier, way more heat resistant. Trying it out for the first time.
Booms installed.
Both bays (front and rear) painted with primer and speckled finish.
Old 05-03-2023, 07:08 AM
highhorse
highhorse's Avatar
Are the tip tanks optional? I noticed that the early pics of this model didn’t have them.
Alan Cardash ignored feedback years ago when several of us mentioned that he’d shaped them backwards on his latest model. He got pissy about it even. The subsequent owners have continued to make them backwards. Hopefully others are more forgiving, but personally I can’t un-see them and they are a no-go for me.
Old 05-03-2023, 11:27 AM
Canadian Man
Originally Posted by highhorse
Are the tip tanks optional? I noticed that the early pics of this model didnít have them.
Alan Cardash ignored feedback years ago when several of us mentioned that heíd shaped them backwards on his latest model. He got pissy about it even. The subsequent owners have continued to make them backwards. Hopefully others are more forgiving, but personally I canít un-see them and they are a no-go for me.
For sure! The kit comes with a set of Tip Tanks and a set of Normal wing tips. Easy to swap, 1 bolt.
Old 05-07-2023, 08:19 AM
Canadian Man
Servo and Gear install
Old 05-09-2023, 04:28 AM
Canadian Man
Wing Tips held on with one tabbie and single bolt. Both wing tips the same setup.
Skycandy leading edge light install!
Wing plug in. 9 Pin Ashlock connector for everything.
Added the outside coller to the skids. Missed this when first installing.
Old 05-09-2023, 04:30 AM
Canadian Man
Boom wire connectors
Main gear doors.
Old 05-10-2023, 07:17 AM
Canadian Man
2nd last video! Almost complete.
AEROSHELDON (05-10-2023)
Old 05-17-2023, 04:33 AM
qcsteve
I enjoy watching your video series. I ended up ordering the boomerang with the 10% discount. I currently fly a a Version 1 of the Elan boomerang. That model is such an excellent flyer that xl should be even better.
Old 05-17-2023, 06:26 AM
Canadian Man
Congrats! I'm sure you will enjoy the Super even more!
Canadian Man
Final Video in the Series! Next up, Maiden flight!
Old 05-18-2023, 07:15 AM
Canadian Man
Final batch of pictures and final remarks.
Old 05-18-2023, 07:19 AM
Canadian Man
Legs were a little soft for my liking. Mains. Took strut apart and added a piece of Tygon inside the spring. This 15mm extra sitting past the spring seemed to be the perfect amount. Easy solution. There is a 2 stage spring installed but full fuel and smoke it not stiff enough.
Old 05-18-2023, 07:39 AM
Canadian Man
Overall thoughts from the project.
- Surprising how small the box is for such a large aircraft. It's very well thought out. The way the booms come off of the fuse, leaving the front part of the boom permanent on the fuse is perfect.
All the parts and pieces end up very well sized and fitting in basically any vehicle is possible.
- Easy to assemble. Pull fuse out, drop gear and as it's sitting on the ground on it's legs everything can be assembled. All the fixing and fasteners are from the top, only one small fastener on each boom is underside.
- All the supplied hardware was used on the servos. The 4mm rods and metal balls are great. Stiff and strong. The supplied balls had a small amount of play in them. I find this if very common on plastic ones as well. I take care of this by
applying a drop of oil on the ball and then a drop of thin CA. Works great. Didn't use the supplied hardware for the doors as my install didn't allow this. If the front hinges on the door are lined up properly at install, stock hardware could be used. If a mini servo was used on the mains then the stock hardware could be used.
- Full composite is very nice. Boomerang has always been known for using covered aircraft or a combo (composite fuse and Wood/covered Wings). The Super Elan is Full Composite. 2 sets of wing tips included and easy to swap.
- Fuel tank is exactly 7L. I marked mine at 5, 5.5, 6, 6.5. I suspect I will only be filling it to the 5.5 or 6 mark and still getting long flights.
- Lots of room in the front end of the aircraft. Easy to hide wiring and mess under the installed trays.
- I am using a 3Cell 3300 LIPO for turbine, 3 Cell 5000 LIPO for Smokepump and lights, 2 x 5000 Mah LIPO's for gear and Central box/RX power. With this battery load I added 450 ish Grams of Lead in the nose.
This weight is removable so some of it may end up coming out. CG is currently at the back edge of the Main Wing Tube.
The Elan has been around for a long time. The Super Elan is BIG, Will be an easy flier and It's the Aircraft that grows with you! If you a rookie pilot they are easy to fly, if your an experienced pilot they are tons of fun to throw around.
If you have any questions the video series may cover it but ask away on here or shoot me an email. [email protected]
The following 2 users liked this post by Canadian Man:
AEROSHELDON (05-18-2023), Sparhawk (05-18-2023)
Old 05-31-2023, 06:14 AM
Canadian Man
First 3 Flights! Such a Sweetheart to fly!
AEROSHELDON (05-31-2023), LimitDwn (06-01-2023)
