Servos twitching
Hi all has anyone seen this before it’s a new build jeti ds16 with a rex 10 and a cortex gyro running Mc Gregor MG2611WHV ,when the turbine x45 gets to a certain rpm the rudder starts twitching if I increase power it goes,I haven’t plugged the other servos in as yet can’t say if it’s on all surfaces
My Feedback: (46)
This issue is caused by acoustic noise from the turbine being picked up by the Gyro. The remedy is to build a soundproof box around the Gyro. We have one available now specifically for a Cortex Pro.
https://aeropanda.com/products/hush-...69c293a2&_ss=r
Danny
Danny
Skunkwrks (05-09-2023)
Danny
Danny
Just food for thought.
Patrick
Guys….the cause of this is noise from the turbine. Not servos or where the gyro is mounted. This phenomenon has been observed since mems type,gyros started being installed in turbine model aircraft. It can affect every manufacturers gyro system. It can be caused by any manufacturers turbine. The solution is shield the gyro from the noise.
zx6rg2 (05-10-2023)
If you are not married to the Cortex, the Smoothflight SF16 latest version has a turbine filter that eliminates the unwanted servo movements caused by turbine noise. It has off, low, medium, and high filter settings.
Tone
Tone
zx6rg2 (05-10-2023)
