Reload this Page >
JR 28X charger
JR 28X charger
Old 06-01-2023, 11:02 AM
JoelP
My Feedback: (20)
Default JR 28X charger
Does anyone know where I can find a charger for this radio? I’m having no luck, no reply from Dee Force or JR Americas.
Old 06-02-2023, 09:36 AM
sewbusy
Hi Joel... I'm not sure where you can pick one up, however, the input/output is as listed below...Not sure if you still have your charger for reference:
Model NO: NEC-A1530
Input: AC100-240V
Output: DC 15V @ 2amps. The outer section of the plug (which goes into the 28X) is Negative, & the center section is Positive
Hope that helps,
BTW.... JR Americas closed down years ago and Dee Force is the owner/distributor of JR.
Wayne
Old 06-02-2023, 10:43 AM
JoelP
My Feedback: (20)
Thanks for the reply. These adaptors are no longer available. I ordered one off of Amazon with the same specs of the JR one including polarity. Fingers crossed it doesn't make the magic smoke!
Old 06-02-2023, 05:15 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
While Wayne is normally up to speed on this stuff, his description of the plug polarity is opposite of the "normal" JR setups which use a center pole negative and an outer pole as positive. I cannot speak to a 28X specifically as I've never had one, but all my other JR radios had the plug I described.
IIRC, Wayne fly's a 28X so that may be the best information.......
Old 06-03-2023, 04:09 AM
sewbusy
I KNOW of what I type!
Wayne
