 BVM Aggressor 1 help >
Old 04-18-2004 | 07:08 AM
Default BVM Aggressor 1 help
I just picked un an early BVM Aggressor 1 the other day. Complete kit, and and all parts are there, but it seems to be missing the plans.
Anyone have a set lying around they might be willing to part with?
Thanks!
Jeff
Old 04-18-2004 | 09:03 AM
My Feedback: (171)
Default RE: BVM Aggressor 1 help
Jeff....just give BVM a call and they will sell you a set of plans for $15 and a instruction book for $25 .Its a good idea to get aquanted with BVM cause you will be calling over there for parts.When you order your plans make sure and get there areo epoxy kit its awsome and you will need it.I' working on a overhaul of a Ultra Viper and it seems like I have to order parts every week.Doing final instalation of powerplant so should be ready soon.Good luck....Lou
Old 04-18-2004 | 09:11 AM
Thanks for the reply, Lou. I spoke with BVM before I bought the kit, and they said they no longer have plans or most other support for it. The kit was such a deal, I couldnt pass it up. It came with an updated instruction book, which is pretty comprehensive, but no plans. Even with no full size plans, I have no doubt I can build this thing the right way....and pretty quickly. It would be nice, however, to have the plans for reference.
I bought several tubes of Aeropoxy from my local BVM stocking dealer, so good to go in that department.
Thanks again, and good luck with your UV.
Jeff
Old 04-18-2004 | 09:14 AM
My Feedback: (8)
Jeff,
You are going back about 17 years herer. If memory serves me correctly there weren't any full size plans for that bird. There was a sheet which showed the flap and aileron bellcrank lincage setups and a small pic of the fuse showing the CG and such. I would doubt it if BVM even had any of that info lying around. I do know they have the CG info still.
Good Luck buddy,
Old 04-18-2004 | 04:46 PM
Thanks, John. I appreciate the info!
Jeff
