Reload this Page >
Black exhaust smoke
Black exhaust smoke
Old 06-08-2004, 09:16 AM
rpmtech
Default Black exhaust smoke
All our vintage jets are missing is that light black{or heavy depending on the plane} exhaust trail. Wouldent that be the *****?
Imagine like an F-4 or F-86 or Mig-15 with that
When I watched the vid of the big B-52 that was all that was missing and made me think of how it could be done, any ideas?
Old 06-08-2004, 10:39 AM
volkan
Default RE: Black exhaust smoke
make a carbon trail and mess up everones lungs???
Old 06-08-2004, 05:41 PM
unknown
Instead of 5 to 1 oil mix put 2 to 1 oil mix. that should do the trick . Or restrict the inlet air so the engine burn rich.
Old 06-08-2004, 07:23 PM
rpmtech
I got the idea playing Microsoft Combat flight sim 3, the jets look cool with the exhaust trail[8D]. I'm wondering if there is any type relatively safe and cheap liquid that would make a light black smoke to be used in place of standard smoke oil.
Just food for thought.
Old 06-08-2004, 07:37 PM
scubyfan
Why not just use the smoke oil? That is, inject it aft of the turbines in the traditional method. That way, it can also be controlled at will. For someone spending thousands on a jet kit and engine, it would see justified, especially for scale fanatics.
Old 06-08-2004, 07:45 PM
J. Campbell
My Feedback: (31)
because the smoke oil is white. He want Black, would be NEAT if someone could figure out how to turn the smoke oils color to black. Maybe Dissolve a bunch of charcoal in it.
Old 06-08-2004, 11:38 PM
scubyfan
I thought you could get it in a variety of colors. [sm=drowning.gif]
Old 06-09-2004, 10:13 AM
grinder-RCU
grinder-RCU's Avatar
I had asked this question about an yr ago and nobody was sure on how to make darker colour smoke. I'm starting an C-130 132" ws and would also like to simulate turbo-prop smoke trails. If it's feasible. without adding to much weight.
Grinder.
Old 06-09-2004, 10:15 AM
grinder-RCU
http://www.mdw-aviation.com/
Old 06-09-2004, 10:24 AM
Shok
My Feedback: (28)
Shok's Avatar
ORIGINAL: grinder-RCU
all your going to get is white
Old 06-09-2004, 11:35 AM
Turbulence
My Feedback: (76)
Turbulence's Avatar
I have heard that you can make it any color by adding food coloring to it, I have not tried it, but then you have to pay for everyone's cleaning bill???? Any one want to try it??
Turbulence
Old 06-09-2004, 04:47 PM
J. Campbell
My Feedback: (31)
can you get Black food coloring in the 1 to 5 gallon size? Wonder if Kroger carries that? [&:]
Old 06-09-2004, 04:57 PM
Turbulence
My Feedback: (76)
Turbulence's Avatar
You add the food coloring to the Smoke oil, but then again if you where using such equipment you would know that already
Turbulence
ORIGINAL: jrc316
Old 06-09-2004, 05:16 PM
rpmtech
I cant imagine food coloring doing anything but changing the color of the liquid, but I could be wrong.
Thanks for the input guys.
Old 06-09-2004, 05:21 PM
rpmtech
This is from the MDW smoke oil site:
On Color Smoke
Sorry, you'll just have to be satisfied with the best white smoke available from MDW.
Many have asked us for color smoke. Indeed, some entrepeneurs (a.k.a., con men) have over the past years gone to market to sell color smoke oil, even bragging about the various colors available.
Get real.
With the internal combustion engine exhaust, into which you inject our oil, you will always get white smoke. Those who sell you color smoke oil are pulling a fast one on you. You may see a color in the oil, but when injected into the exhaust stream, you will get white smoke. You may end up with your plane or body stained by the oil, but you won't see color smoke. Buyer beware!
Smoke "bombs", on the other hand, may produce color other than white. These devices are available from selected hobby distributors but are not of the same family.
Maybe it really cant be done very easily[]
Old 06-09-2004, 05:45 PM
Shok
My Feedback: (28)
Shok's Avatar
ORIGINAL: Turbulence
Turbulence
nope, you can change the liquid color but not the smoke
Old 06-09-2004, 07:02 PM
JetflyerJ
Banned
My Feedback: (67)
If you want Black smoke Just get Used Tranny Oil and you'll get it. The problem with the used Transmission Oil is that the pump will only run three to four flights Max, No matter what pump you use, I tried them all with the exception of the AMT Pump.
Best regards........... Johnny Hernandez
Old 06-09-2004, 08:11 PM
J. Campbell
My Feedback: (31)
I KNOW you add food coloring to the smoke oil DUH! You would have to add a lot though and have a lot on hand is what i was getting at.
Old 06-09-2004, 08:32 PM
Shok
My Feedback: (28)
Shok's Avatar
ORIGINAL: jrc316
I can pretty much guarantee that it does not matter how much color you add to the oil, it is still going to burn white.
The only way it will keep the color is to dump straight liquid out the plane without burning it.
Old 06-09-2004, 08:48 PM
J. Campbell
My Feedback: (31)
i would agree, We went through this thread on the rc-jets forum in 99 when the ram 750 came out. No One ever figured out how to do it then either if im not mistaken.
Old 06-09-2004, 08:59 PM
mgary
Just a thought; plastics give off a black smoke when it is burning, if there were a way to liquify styrene or inject powdered plastics into the exhaust it may work?
Gary
Old 06-09-2004, 09:39 PM
Shok
My Feedback: (28)
Shok's Avatar
that would be a pretty toxic cloud though that it left behind.
Old 06-09-2004, 09:54 PM
mgary
You think that's toxic, sniff an erupting volcano!!
Gary
Old 06-09-2004, 10:20 PM
rjbob
My Feedback: (8)
rjbob's Avatar
Since the trace of black smoke coming from the exhaust of older jet engines is from inefficient burning of the fuel, couldn't we simulate this slight smoke trail by injecting the exhaust of our turbines with jet-A instead of smoke oil? That could possibly simulate inefficient fuel burn and give off the desired trace of black smoke. If it works, an added benefit is that it would be less expensive than smoke oil.
Bob Edison
Anchorage
Old 06-09-2004, 10:58 PM
scubyfan
ORIGINAL: rpmtech
On Color Smoke
Get real.
What about real-sized jets that use red, blue, and other colors? What method do they use? Would it be so difficult to scale it down?
