Reload this Page >
new Arf Boomerang 14lb thrust
Old 10-25-2008, 02:42 PM
  #2576
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Default RE: new Arf Boomerang 14lb thrust
You have to love those low passes, my buddy did the same thing over a year ago, look at post #8 in the following thread.
http://www.rcuniverse.com/forum/m_63...tm.htm#6300402
He was able to "Trim" both booms
His repair was quite simple, glue in a block of balsa to the bottom, reshape and cover, now you can't tell it ever happened.
Old 10-25-2008, 02:46 PM
  #2577
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Here is a shot from our field in Titusville PA a couple of weeks ago.
It was sort of an impromptu Boomerang gathering, we had the whole Boomerang Family in attendance, (XL, Elan, Baby and the Sprint), my Formost was the half brother as it contains the CF rear spar from an XL.
Old 10-25-2008, 05:03 PM
  #2578
AVIOJET
AVIOJET's Avatar
ORIGINAL: Felix Barrao
This is my "low pass" record. Theother day, in a high speed pass, the plane went to the floor, and after take off, and continue fliyng !!! with the right aileron loose, (see the pic). After one turn, and check that the landing gear was out correctly, landing without problems.
This plane fly very well with only one aileron, ( only a little slower in the reactions).
Félix
Felix, I am thinking to fit some kind of rollers at the bottom of my BB's tail booms.
B.R.
.Jesus
Old 11-10-2008, 02:01 AM
  #2579
akaram
akaram's Avatar
Guys,
Would like to share with you the photos of my Boomerang which I maidened this Saturday. I have a Wren Supersport on it, I loved the plane, it is a joy to fly and so easy and stable. One problem I have is that when I trim the elevator at low speed, the plane climbs at full throttle and on the contrary if I trim it to fly straight at full throttle it sinks a lot at low speed. I read before about some of you having this problem but dont remember how it was solved and it is a burden to read all the thread again (almost impossible). Would appreciate any input on that.
I put a total of 4 flights on it this weekend, on the 4th flight the landing was a bit hard, there was a strong headwind and the plane almost stopped at 1 meter over the runway and dropped down. After examining the center wing section I found 4 cracks on both sides around the servo wire access hole caused by the weight of the tailbooms which transmitted the force on impact through the dowels. Had anybody have this happen to his boomerang ? What is the best way to fix it ? I feel I should remove some sheeting from the bottom of the center section to be able to strengthen the 2 outside ribs ! I am thinking of adding a 2nd dowel closer to the leading edge to distribute the force and lessen the stress on a single point.
ID:	1069285   Click image for larger version
ID:	1069286   Click image for larger version
ID:	1069287   Click image for larger version
ID:	1069288   Click image for larger version
ID:	1069289   Click image for larger version
ID:	1069290   Click image for larger version
Old 11-10-2008, 08:14 AM
  #2580
KC36330
ORIGINAL: akaram
..........One problem I have is that when I trim the elevator at low speed, the plane climbs at full throttle and on the contrary if I trim it to fly straight at full throttle it sinks a lot at low speed. I read before about some of you having this problem but dont remember how it was solved and it is a burden to read all the thread again (almost impossible). Would appreciate any input on that...........
shim the front of the turbine up with a washer.
Old 11-10-2008, 08:25 AM
  #2581
akaram
akaram's Avatar
One washer will be enough ? or should I start with 2 washers ?
Old 11-10-2008, 10:03 AM
  #2582
ltdorn1
My Feedback: (39)
for the trim change....
1. make sure the stab is fully and truely seated in the two booms.
2. if it is seated completely flat on the booms, then you need to shim the front* of your engine up a bit. Try one or two thin washers under front bolts. you need some down thrust on the turbine.
Lawrence
Old 11-10-2008, 01:18 PM
  #2583
highhorse
highhorse's Avatar
ORIGINAL: akaram
re-read the thread...Im know I've seen several posts exactly answering your question. U may find a poster with your same engine etc. Different engines require more/fewer washers, but you DO need to shim.
Old 11-10-2008, 11:55 PM
  #2584
Ayrtonsenna
One other thing- have you checked the indecence on the stab, tobe honest, I needed alot of up elevator trim for straight and level flight, and after checking the C/G again I then found that the stab was sitting at +2 degrease.
Once I'd reset with washes ( 0 degrease ) I've removed all the trim, and it now flys straight and level through all throttle settings.
Good friend who flys a BB found he had the same problem-
Ants
Old 11-11-2008, 02:10 AM
  #2585
akaram
akaram's Avatar
Senna, I thought of that as a possible problem, but how can you measure this incidence, looking at it from the front and from behind and the side and from far away does not reveal any defects, is there a special tool you use to exactly measure incidence ?
Old 11-11-2008, 03:01 AM
  #2586
nt flyer
nt flyer's Avatar
Hi Akaram. Try this one http://www.robart.com/how_to/incidence_meter.aspx
I used a tapered plywood shim on the top of the fin, and have it set to zero. I have no issues with trim change!
Cheers,
Greg
Old 11-11-2008, 04:09 AM
  #2587
akaram
akaram's Avatar
Thx nt flyer, looks great, I put it in my wish list great tool to have
Old 11-11-2008, 04:43 AM
  #2588
akaram
akaram's Avatar
I will wait for that tool to arrive and check the stab. I am grounded anyways waiting for the front retract replacement parts to arrive which Sandor was kind enough to ship immediately and for free !!!
Old 11-20-2008, 02:33 AM
  #2589
afftced
My Feedback: (8)
Guys,I need top hatch and canopy. It fell apart from the air.
Old 11-20-2008, 09:08 AM
  #2590
B58
My Feedback: (43)
I believe that you can get one from Patricia. I had to replace mine a year or so ago. Bob
Old 12-08-2008, 07:51 PM
  #2591
PeterDays
Has anyone seen this Boomerang on floats?
Check it out:
http://br.youtube.com/watch?v=k6c-LweM-VM&NR=1
Old 12-08-2008, 11:22 PM
  #2592
akaram
akaram's Avatar
Ayrtonsenna and nt-Flyer please let me know what turbines you are running and if you have shimmed them too in addition to shimming the stab.
I received the incidence meter and found the stab to be sitting at 2 degrees, I shimmed it at the back to get 0 degrees + I shimmed the front of the turbine with 2 washers.
Flied it and found the problem to be less pronounced now but it was still there, I am wondering if I overdid it. Maybe I should remove the shims from the engine ?
What I didnt like most after those modifications is that now during inverted flight to fly level I need to apply at least 50% down elevator which is toooo much !!!
Old 12-09-2008, 02:41 AM
  #2593
nt flyer
nt flyer's Avatar
Hi Akaram. My Boomer has a PST600R. No shimming on the engine. My tail was also about 2 degrees out, which is where I made the shim.
Where is you C of G?
Cheers,
Greg
Old 12-09-2008, 05:25 AM
  #2594
akaram
akaram's Avatar
My CG with just the UAT full is at 185mm from the LE where the wing meets fuse. Where is yours ?
Old 12-09-2008, 01:31 PM
  #2595
Ayrtonsenna
Hi Akaram,
I'm running a P70- with no engine shim, my tail was also about 2 degrees out- but after packing the "trailing edge of the stab up"
I now require no trim for straight and level flight- thanks to Greg for pointing this out to me!
Ants
Old 01-19-2009, 03:47 AM
  #2596
akaram
akaram's Avatar
Senna, after you shimmed the stab, did you notice that now you need too much down (like 60%) to fly level when inverted ??? Before shimming mine flew inverted great requiring only a tad of down, Now after shimming I need loads of down to keep it level in inverted flight and the tendency to climb at full power is still there !!! much less than before but there !!! it is really annoying !!!
Old 01-20-2009, 03:28 AM
  #2597
Ayrtonsenna
Hi Akaram,
Once I shimmed the stab, I removed all the trim, and she now fly's great! even when its inverted, I didn't touch the engine mount (P70) only the stab
To be honest, I'd start checking everything again, you may have mist something-
Start with the wing incidence to the stab again, I'd also check the C/G, is it possible you may have some positive up on both your ailerons?? make sure there both neutral when the models switched on-
Any ideas Greg?
Hows that F15?
Ants
Old 01-20-2009, 03:52 AM
  #2598
akaram
akaram's Avatar
Good idea, will check that, I have them ailerons aligned with the wingtips, will check maybe both are down a bit causing this effect.
Old 03-02-2009, 03:57 PM
  #2599
siclick33
I'm sure I've read this somewhere but can't find it.
I have glued the wing to the fuselage and believe I have made a pretty good job of it. What have you done to the inside to reinforce the join? Is a bead of Hysol enough or do I need to put a bit of cloth and resin or fillet across the join?
Old 03-02-2009, 04:22 PM
  #2600
ThomasP
On mine, removed the covering, glued the wing assembly to the fuselage (used 30min epoxy) after 24 hours applied a substantial fillet of Hysol all the way around, no problems after two years
