Reload this Page >
Reaction 54 Jet Kit
Reaction 54 Jet Kit
Old 01-15-2011, 08:40 PM
  #2651
DREAMER-RCU
Default RE: Reaction 54 Jet Kit
Today, at E-Jets of the West my 83% scale (64"ws) EDF Reaction recorded a radar speed of 135mph. Not bad for a 4.5" fan pulling 62 amps on 12s, 5000.
Old 01-30-2011, 05:34 PM
  #2652
JustFlyIt
I am currently building a Reaction 54 and really appreciate all the information that this thread has provided. I really feel that my chances for success are greatly increased having read it.
A couple of questions and clarifications:
I would like to use the Prolink trailing links because of their additional function and they look awesome (nothing against the Robart wired setup). I see that most guys have used the small links for the nose and main. The Dreamworks web site shows two sizes of small links for the nose and mains. The nose has 3/16ths and 1/4th. The mains are 7/16ths and 1/2. Can someone tell me which ones are the most appropriate size?
I am assuming that the wheel well location and dimensions have to be adjusted because of axel length etc. Is this true or is there something else that I should be looking out for?
I have already ordered my Kevlar fuel tank from Gary. I am on using my 9503 JR transmitter and the 9000 receiver. I not sure what I want to do for a receiver power supply...thinking about the A123 batteries. Any thoughts on this?
Don S.
Old 01-30-2011, 06:09 PM
  #2653
rcguy!
My Feedback: (69)
rcguy!'s Avatar
ORIGINAL: JustFlyIt
Don S.
Go with 2pcs 2 cell A123 packs EACH thru its own switch harness and then directly into your 9 channel RX. No need for regulators what so ever. Works for me for 3 years in anything from a KingCat to my 115% size 'Over Reaction".
Dave Rigotti
Old 01-30-2011, 06:28 PM
  #2654
JustFlyIt
Dave,
Thanks for the A123 advice. Is there a perferred vender and what mAh should I look for (yes, this is my first round with A123s).
I am putting my Wren 75 in my Reaction and I am really pumped for it. Soon I am going to start collecting fuel and field equipment. This is a whole new world for my from my warbirds....awesome.
Don
Old 01-30-2011, 07:15 PM
  #2655
bobparks2
There are only 2 sizes, about 1100 and about 2200 mAh. I imagine that you want the larger ones. (they are pretty light, and R54 usually want some nose weight anyway).
Make sure you get the brand name A123 cells. There are some clone cells out there of unknown quality. Once you have the real cells, any good vendor should be fine.
Bob
Old 01-30-2011, 08:15 PM
  #2656
PaulD
My Feedback: (39)
PaulD's Avatar
Sincity jets has made up packs for a reasonable price:
http://www.sincityjets.com/store-batteries.htm
PaulD
Old 01-31-2011, 06:00 AM
  #2657
racer8297
My Feedback: (13)
JustFlyIt,
I used the DW trailing links in my Reaction. Got almost 400 problem free flights off of grass and then sold it. The guy who bought it is still having the same problem free experience!
On mine I used the small 7/16" mains which required the wheel wells to be extended about 1" and offset to the rear by .25". In the nose I used the small 7/16" gear which just dropped in. You will need more clearance in the nose above the wheel when it is retracted.
Jim
Old 01-31-2011, 06:52 AM
  #2658
JustFlyIt
Bob and Paul,
Thanks for the info on the A123. I will go the larger size and get those ordered. I didn't want to go Lipo or NiMh. I am also glad to hear that the two switch setup into the receive will be good enough. I wasn't against going with a power system with regulators but don't have a clue about them. Glad the issue goes away.
Jim,
I don't see the 7/16" nose gear on the DW site. I see the 3/16" nose gear. Is that what you used?
Don S
Old 01-31-2011, 06:57 AM
  #2659
knifeedgeyak
Sounds like you have your power system all sorted out. I am almost done with my airframe. I am using the Fremeco Wolverine switch. It has redundency built into the switch. I am using 2 2200mah nicads.
http://www.airwildpilotshop.com/More...product&id=702
Old 01-31-2011, 08:14 AM
  #2660
racer8297
My Feedback: (13)
Don,
So sorry! I meant to type 1/4" for the nose gear.
Jim
Old 01-31-2011, 06:17 PM
  #2661
JustFlyIt
Jim,
Good deal...I see the quarter inch strut on the DW web site. I think that I will use the Intairco (spelling) brakes and wheels and brakes. That should hook me up. Now to put all the parts together!
Don
Old 01-31-2011, 06:26 PM
  #2662
racer8297
My Feedback: (13)
Don,
I used the Intairco brakes/wheels also. They work great!
Jim
Old 02-08-2011, 02:00 PM
  #2663
JustFlyIt
Ok, I am almost set except for servos. Bruce's FAQ suggests HS-5625MG and HS-5645MG. I have looked through the thread and saw some info. Does anyone have anything current to add for servo suggestions? I am not afraid to send money for safety but I don't want to throw it away either.
I don't have a problem with Bruce's suggestion...just want to know about options.
Don
Old 02-09-2011, 11:52 PM
  #2664
maxvertical
maxvertical's Avatar
I'm using HS 5985's and HS 5645's. However I did have a 5645 on one of the flaps go south on me after about flight #30. Both of these were swapped out for HS 5485HB's and so far no issues and the airplane doesn't seem to notice the slightly less torque on the flap but then again I bleed the speed WAY off before putting them out.
MV
By the way, I have Hitec servo's in most of my airplanes even though I fly Futaba. The single flap failure has been the only real failure I've seen and has not influenced my choice to use HS equipment.
Old 02-10-2011, 12:40 AM
  #2665
maxvertical
Guys, I just spent four days with Bruce at his Rogue Valley shop at the end of January, what a gracious host, and one fine designer builder. I also got to see the little gnomes he employs to pack his boxes.. lol, he does everything himself and says that's what the "E" in BTE is for.. Engineering the box.
He's currently buried in UAV projects but once he's done, maybe we can talk him into something new and fun.. Just maybe.. Ok, I'll stop because I've not grown fond of duct tape over the mouth. "waves at Bruce" We might just see an article on Bruce in a future issue of JPO magazine, Just maybe.
While this is a Reaction thread, I don't think he would mind if I shared with you a picture of the inspiration for the Reaction 54....
Enjoy!
ID:	1561105   Click image for larger version
ID:	1561106   Click image for larger version
ID:	1561107   Click image for larger version
Old 02-15-2011, 07:40 AM
  #2666
JustFlyIt
Guys,
I spoke with Todd at Dreamworks and he told me that the 3/16's inch wire off of the Robart retracts will not work with the Prolinks (1/4" nose, 7/16" mains). I get the impression from these pages that most of you that used the Prolinks mounted them on the Robart retracts from Bruce. What am I missing?
Don S.
Old 02-15-2011, 10:51 AM
  #2667
JustFlyIt
I always love a chance to demonstrate my ignorance. The Robart retract uses a trunion bushing for the 3/16"s wire. Without the bushing it the size is 7/16", what I need for the Prolink small mains.
I am slow but usually I catch on.
Don S.
Old 02-20-2011, 05:32 PM
  #2668
Pitts S1S
My Feedback: (9)
Well the 3 piece wing works fine, Jim got the maiden flight in this morning with a Kingtech K80 for power.
[youtube]http://www.youtube.com/watch?v=7ijWMze-VEE[/youtube]
Jeff
Old 02-20-2011, 09:04 PM
  #2669
BruceTharpe
BruceTharpe's Avatar
Congrats Jeff and Jim! Great flight and excellent video. Really liked that second approach and landing. Sweet!
First one I know of flying with the K80. Looks like it might be a good choice for the R54.
Old 02-23-2011, 01:19 PM
  #2670
speedbrake
speedbrake's Avatar
Something I always wanted to experiment with are spoilers on the R54. I finally got around to it with airframe #3. The spoiler well is centered above the bottom wing hatch just aft of the top spar. It is nine inches long and one inch in width. A small servo in the hatch area will actuate the spoiler. My hope is to be able to point the nose down at a spot on the runway and land without ballooning. I want to use flaps and spoilers together to create sufficient drag to make landings very predictable. The spoiler is taped in the photo..but it will be hinged after the wing is covered.
ID:	1568796   Click image for larger version
ID:	1568797   Click image for larger version
Old 03-01-2011, 12:52 PM
  #2671
Pitts S1S
My Feedback: (9)
Well Casper is DEAD!!
Jim got some color on his Reaction today! Looks pretty good for Ultracote!!
Jeff
ID:	1571811   Click image for larger version
Old 03-01-2011, 01:28 PM
  #2672
knifeedgeyak
Man that looks great.
Old 03-01-2011, 01:58 PM
  #2673
cjshaker
That looks ravishingly good!
Chris
Old 03-01-2011, 03:27 PM
  #2674
Ayrtonsenna
Nice work Jeff..
Old 03-01-2011, 04:43 PM
  #2675
Pitts S1S
My Feedback: (9)
I can't take credit for it, I just built it. Jim had another Jim in FL airbrush some vinyl, cut it out, then stick them on.
Some close up shots.
Jeff
ID:	1571893   Click image for larger version
ID:	1571894   Click image for larger version
