Reload this Page >
Reaction 54 Jet Kit
Reaction 54 Jet Kit
Old 12-02-2019, 06:47 PM
  #4476
CARS II
My Feedback: (7)
CARS II's Avatar
Some more.
Old 12-03-2019, 11:26 AM
  #4477
joeflyer
My Feedback: (48)
Carlos,
Good idea using o-rings on the wing hold-down screws.
FWIW, I've used large nylon or aluminum screws to hold wings on a number of planes in the past. Too often the screw driver would slip out of the screw slot and ding the wing while tightening. For that reason I went with hex head aluminum bolts on my R54. I use a small ratchet with socket to install and remove them. It's much easier on the Monokote.
Joe
Old 12-03-2019, 11:53 AM
  #4478
CARS II
My Feedback: (7)
CARS II's Avatar
Joe
I hear you on the screwdriver dinging the wing, I like the idea of the hex head aluminum bolts.
Thanks.
Old 12-03-2019, 09:42 PM
  #4479
CARS II
My Feedback: (7)
CARS II's Avatar
The wing is also getting gray primer paint.
Old 12-03-2019, 09:58 PM
  #4480
CARS II
My Feedback: (7)
CARS II's Avatar
Here is a pic with a Futaba servo, I tend to use Hitec servos as much as possible, in this particular use I had to install a Futaba servo because it rotates the opposite direction when compared with the Hitec servos, since I run out of channels I had to Y the steering to the rudder, after installing a Hitec servo for steering I noticed that when the rudder was moved to the right the nose wheel moved to the opposite direction, ok I said, I got me an MPI servo reverser extention, well, the servo didn't like it and it was moving erratically when at idle then I read on an RCU thread to swap it with a Futaba servo, I got this servo from my LHS for $1, I told the guy that sold it to me what it was for and he said flat out, is not going to work, I said, really? and there it is, working perfectly.
Old 12-04-2019, 12:12 AM
  #4481
CARS II
My Feedback: (7)
CARS II's Avatar
Done with all the checks, fuel, controls, electrical, engine and components and the most important, CG, I removed about 3 oz of lead from the nose, it still has 6 or 9 oz of lead in the nose cone, the CG came out at the very aft limits per the plan so, since we know that the model airplane designers are very conservative on the CG point to help the builders not to screw up during the maiden flights then I'm ok where is at, it should rotate easy on TO and hopefully it will be easy to fly when inverted and also looking for axial rolls here.
I've also done some mods to the exhaust deflector, it was a bit heavy, added some gray primer and most likely I will be painting the tube with the heat resistance black paint that I got for the Turbinator's exhaust deflector plate, notice the front of the tube, I added a sliced rubber tube from the hardware store to stop the front of the exhaust deflector tube from touching the back of the turbine, the exhaust deflector tube is a must have with this airplane, specially if your turbine is Kero start ( most of them are now days )
The Reaction is ready to fly but, there is still a bunch of things that I will be adding to it, these are mainly cosmetic.
Old 12-04-2019, 12:38 AM
  #4482
CARS II
My Feedback: (7)
CARS II's Avatar
I has been over an hour since I refilled the air bottles and the needles are at the same position with the brakes off and gear in the up position, very nice I will check again tomorrow morning.
Done for tonight.
Old 12-04-2019, 02:01 PM
  #4483
CARS II
My Feedback: (7)
CARS II's Avatar
And over 12 hrs later, practically, no changes on the position of the needles.
Time to run the engine.
Old 12-04-2019, 02:45 PM
  #4484
CARS II
My Feedback: (7)
CARS II's Avatar
Just run the engine, very clean start, crispy throttle response with the throttle curve set to linear, I don't like the factory set of half expo, too slow for go arounds, with a linear curve the max rpms are there in an instant when needed.
Old 12-04-2019, 03:12 PM
  #4485
CARS II
My Feedback: (7)
CARS II's Avatar
I was checking the temp and PW readout at max rpms, they are well below the max limits programmed in the ECU.
Old 12-04-2019, 08:09 PM
  #4486
CARS II
My Feedback: (7)
CARS II's Avatar
Something like this.
Old 01-09-2020, 02:33 PM
  #4487
CARS II
My Feedback: (7)
CARS II's Avatar
Some Reaction action happening right now the Reaction is an airplane in my fleet that I haven't flown after my eyes sergury, it sure will be enjoyable to take it to the skies once again, this time it will be more relaxing for sure.
Giving her some personality before it's back in the air, I also will be adding some of the stickers I have and some that I will get from Callie graphics.
I saw Jeramy doing the same thing to his reaction and I wanted to do the same, I felt it was incomplete.
ps: the cub stickers remains me that the yellow it is covered with is Cub Yellow and the how easy this airplane is to build and fly.
Old 01-09-2020, 02:49 PM
  #4488
CARS II
My Feedback: (7)
CARS II's Avatar
I flew my Boomerang a week ago, I had not flown this jet after my procedure, I also removed the 27 lbs TJT engine ( the engine is fine) and retrofitted it with a Kingtech 140, 4 extra pounds of thrust, the difference is noticeable, again, seen it very cripy on final and now with an engine that has almost instant thrust is so delightful.
Old 01-09-2020, 03:14 PM
  #4489
RockiesGuy
RockiesGuy's Avatar
Default more Reaction's
You did pretty good re-covering job !! Now mine looks like C#$%P.. will have to cover it again.. it is over 15y.o.
Old 01-09-2020, 03:51 PM
  #4490
CARS II
My Feedback: (7)
CARS II's Avatar
Thank you.
Mine just got painted inside, the covering is the original, my Reaction is one year old with about 15 flights I think.
A friend of mine repainted his Reaction, it is a few years old.
Old 01-09-2020, 08:57 PM
  #4491
CARS II
My Feedback: (7)
CARS II's Avatar
Added some strip tape to the wings also.
Old 01-23-2020, 01:41 PM
  #4492
CARS II
My Feedback: (7)
CARS II's Avatar
Flying my R-54 as we speak ( type ) flight #1 done then some minor adjustments to the steering and ailerons, ailerons low rate was reduced about 10% and 25% expo, high rate is fine with 35% expo, CG is at max aft position, checked on the second flight, the jet holds inverted with almost no down elevator input, rotation on landings is effortless, so far both landings were on the mains, the full flap settings was reduce from about 80 to 60 down, much more manageable approach, on the second landing because it landed so slow breaking was not needed, TOs are more realistic with the first notch of flaps down, with this flaps setting TO rotation is smooth not a jump off the runway, with first flaps down TO rotation can be done at a shorter distance and with a smooth rotation.
The two members that were here left so, no one but me, myself and I, light winds, very high overcast, the temps are ok, warmer tomorrow, more flying to be done here.
The Kingtech 80v1 is performing flawlessly, lots of power at max rpms and throttle response is awesomely fast, the jet now has 3 fuel tanks, 90 oz of fuel total, the timer set to 7 min, fuel remaining in the main tank after 7 min, 30 oz, 1/2 tank, average throttle position during flight is from 1/2 to 2/3.
I hope all this info can help the future R-54 builder/flyers.
Later.
Old 01-23-2020, 04:15 PM
  #4493
CARS II
My Feedback: (7)
CARS II's Avatar
This jet it's amazing how slow it can be flown and the landings, I got 4 flights in all today, I had to thame it a bit on the ailerons, the control throws are the recomended ones but as it should be one has to adjust them to each ones flying style, recomended max throws are there for the wild maneuvers.
After checking the fuel reserves again, it can be flown 7 min with 30 oz of fuel reserves or the flight time can be increased to 8 min.
Again, the CG was rechecked by flying inverted, it is perfect at the max recomended position, I wouldn't recommend moving it passed that point, stalls are forward and none event, so none event that I got it to stall then recovered then without adding power made it stall again.
TOs are more natural with the first notch of flaps down, Im still debating if I should keep the full flaps where they are or back where they were, it now has more residual thrust with the bigger engine and the previous full flap position maybe required, one thing is for sure, it is nice to have all that extra thrust generated by the K80v1.
Tomorrow I go back but with a different bird
Old 01-23-2020, 05:18 PM
  #4494
Afterburners
Afterburners's Avatar
Sounds like a great day at the field!
Old 01-23-2020, 05:38 PM
  #4495
CARS II
My Feedback: (7)
CARS II's Avatar
Yes it was, had a great time.
Old 02-05-2020, 12:05 PM
  #4496
CARS II
My Feedback: (7)
CARS II's Avatar
I'm a bit surprised at the moment, I was reading and having a look at some of the pictures that I've posted here, when I got to the end of the page, to my big surprise I noticed there were 24 non-members viewing this thread, to me, that shows that the interest for R-54 still there.
Old 02-05-2020, 10:44 PM
  #4497
CARS II
My Feedback: (7)
CARS II's Avatar
Tomorrow is Reaction time, I will try to get some TO and Lan vids.
Old 02-05-2020, 10:59 PM
  #4498
rjbob
My Feedback: (8)
rjbob's Avatar
KEWL, Carlos!
Old 02-06-2020, 07:56 AM
  #4499
Eaglepilot2
Eaglepilot2's Avatar
Its a shame the kits have been out of stock so long. I've about given up on getting one.
Old 02-06-2020, 06:29 PM
  #4500
CARS II
My Feedback: (7)
CARS II's Avatar
I'm sure they will be back, just don't know when.
