Reload this Page >
Reaction 54 Jet Kit
Reaction 54 Jet Kit
Old 11-15-2005, 08:18 PM
  #676
Helijet
Default RE: Reaction 54 Jet Kit
We have been flying our Reaction all year with our custom gear and struts. Lots of guys using them with good success off pavement and grass.
Dean Wichmann
www.helijet.ca
ID:	355040   Click image for larger version
Old 11-15-2005, 10:28 PM
  #677
TommyWatson
I fly all the time from grass. No problem with the retracts. I use Unibrakes because I had some. However I now don't see any need for realy powerfull brakes on grass. I have never had to use them in anger. I usually use them to show off to my mates. "Hey guys look I can stop short". It is perhaps a little different when flying from hard surfaces.
Looking back, I think bruce was right.!!!
Regards
Old 11-15-2005, 10:42 PM
  #678
Woketman
Don't forget that the R54 usually needs nose weight. That is the only reason I intend to use the Kavan instead of the many other sets of brakes I have lieing around. Well, that and the fact that I fly 90% off of grass, so I don't need a brake anyway.
Old 11-15-2005, 10:47 PM
  #679
u2fast
My Feedback: (37)
just started monokoting mine tonight. also, the p60 has arrived. woketman, being from lousiana, lets hook up and fly sometime, barry
Old 11-24-2005, 12:47 AM
  #680
bobparks2
I just got a JetTech (Gary Mueller) Kevlar tank for my R54 and thought I would post a photo.
As is typical for Gary's work, its very well made. It drops right into the space on the R54 with no mods to the plane.
I was curious, so measured the capacity of both the JetTech tank and the stock DuBro 50.
The real surpise is that the DuBro is actually 1800 ml, which is 60.8 fl oz, way above the claim of 50 oz or 1500 ml.
The JetTech tank is about 2240 ml, 75.7 fl oz, about 15 oz more capacity than the DuBro.
The tank is $115 plus shipping, email Gary at [email protected] if you are interested.
Bob
Old 11-24-2005, 12:59 AM
  #681
TommyWatson
I have Gary's tank in both my R54's. Also I face the tank outlet to the front and mounted the UAT and Pump on the shelf just in front of the wing. Keeps a bit more of the weight in front of the CG and makes the plumbing easier. I never see any air in my UAT.
Regards
Old 11-25-2005, 11:28 PM
  #682
u2fast
My Feedback: (37)
been busy with work, but back on the monokoting this weekend. barry
ID:	360334   Click image for larger version
Old 11-27-2005, 01:16 AM
  #683
TommyWatson
G'Day Mate,
Looks great. I can't wait to see it complete and standing on its wheels.
Regards
Old 11-27-2005, 08:25 AM
  #684
u2fast
My Feedback: (37)
updat on monokote, barry
ID:	360866   Click image for larger version
Old 11-29-2005, 09:19 PM
  #685
TommyWatson
The Twins at Wangaratta Jets
ID:	362273   Click image for larger version
Old 11-29-2005, 10:54 PM
  #686
u2fast
My Feedback: (37)
still trimming mine out. barry
Old 11-30-2005, 07:08 AM
  #687
causeitflies
causeitflies's Avatar
There's no doubt about it! With a little extra work the R-54 is the best looking sport/trainer jet out there right now
Old 11-30-2005, 07:23 AM
  #688
rcguy!
My Feedback: (69)
rcguy!'s Avatar
Hey Mark,
We gonna see yours fly next season at Ashtabula?
Dave Rigotti
Old 11-30-2005, 08:49 AM
  #689
causeitflies
Dave,
Definitely!!
Old 12-01-2005, 04:40 PM
  #690
Redline7000
Redline7000's Avatar
How long did it take you guys to complete the R54? I've had mine since August and I've just completed both wing assemblies.
Old 12-01-2005, 05:09 PM
  #691
rcguy!
My Feedback: (69)
rcguy!'s Avatar
ORIGINAL: Redline7000
5 weeks at the most
Dave Rigotti
Old 12-01-2005, 05:35 PM
  #692
afterburner
My Feedback: (18)
afterburner's Avatar
Redline 7000,
Don't feel bad, I've had mine since mid July and just finished up the wing a few weeks ago. I think I'm working slow to hold off making the turbine purchase.
Marty
Old 12-01-2005, 06:44 PM
  #693
TommyWatson
I had my second R54 ready to cover in three weeks of part time work. Took a lot longer to finish and install all the stuff.
Regards
Old 12-01-2005, 10:22 PM
  #694
BalsaBob
My Feedback: (24)
Gentlemen, My R54 is a little more than 1/2 way done and I am just starting to assemble the Boat Tail area. I see that the wing mount block (for the bolts) is attached to the Boat Tail. The Boat Tail is attached to the fuse sides and the balsa sheeting on the bottom of the fuse. Is the Boat Tail attached by any additional means to the fuse ? I just want to make sure I am not omitting something. Thanks. Bob
Old 12-01-2005, 10:47 PM
  #695
BruceTharpe
BruceTharpe's Avatar
Sounds like you've got it right. The small leftover portion of the boat tail jig is important too for tying things together. You are right in recognizing that this is a critical part of the structure and needs to be built well - no skimping on the glue! There really is a lot of gluing surface in this area and it ends up plenty strong.
Old 12-02-2005, 02:54 PM
  #696
afterburner
My Feedback: (18)
Is the elevator control horn pad shown on the plans anywhere? The manual says to refer to the plans and offset it from the centerline so the horn will end up in the center I guess. Just want to know before I "wing" it. Thanks.
Marty
Old 12-02-2005, 03:23 PM
  #697
TommyWatson
You just need to find where the pushrod exits the rear of the fuse (should be on the middle of the fuse exit).
Then place the horn on the elevator so it lines up with the pushrod. Place the pad so the horn "foot" is central on the pad.
Regards
Old 12-02-2005, 03:35 PM
  #698
afterburner
My Feedback: (18)
Thanks Tom, that's what I thought.
Marty
Old 12-02-2005, 03:46 PM
  #699
TommyWatson
How far along are you with your R54?. Any pictures?
Regards
Old 12-02-2005, 04:40 PM
  #700
afterburner
My Feedback: (18)
I've only finished the wing, and now the vertical and horizontal stabs. Nothing you haven't seen "twice" in your own shop. I'm going to try to put some real time in on it so there will be more balsa dust on it as opposed to just regular dust. I will post pics when covering begins sometime in ????????????. I've seen a nice red , white and blue scheme on an L-39 that looks highly visible.
Marty
