Reload this Page >
BVM Fill Valve #5758
Old 05-31-2005, 11:05 AM
SJN
Default BVM Fill Valve #5758
Hi guys
My friend has bought a bandit, which included thses BVM fill valves.
What kind of connection fits into this valve ?
we cant find any pictures of the fitting that fits.
Can anyone help
Old 05-31-2005, 11:09 AM
grbaker
My Feedback: (29)
grbaker's Avatar
Default RE: BVM Fill Valve #5758
BVM Fill Chuck #2192
Fill Chuck swivel end to fit 1/4" hose on electronic pumps
For use with BVM Fill Valve's.
Old 05-31-2005, 12:13 PM
rhklenke
My Feedback: (24)
rhklenke's Avatar
Actually the coolest thing about it, and the reason I've gone to them on both my jets, is that a standard air fitting for automobile or bicycle tires will fit right on there. No more worrying if you remembered to bring the right fitting for this or that fill valve... Just clamp the standard fitting from your 12V tire pump right on there.
Old 05-31-2005, 01:37 PM
jkirkon
SNJ,
The BVM valve uses a Schrader valve connection......the same as a automobile tire (here in the USA, anyways).
Brg,
Jeff
Old 05-31-2005, 01:48 PM
SJN
Thanks guys [sm=thumbup.gif]
Old 05-31-2005, 01:56 PM
ianober
My Feedback: (12)
ianober's Avatar
Heres a pic of it from BVM's website:
Old 05-31-2005, 02:10 PM
festus01
the coolest thing is just to use the 1/8" pneumatic tube included in the hardware bag.
the hole is conical and the connection is strong enough up to 10 bar
Martin
Old 05-31-2005, 03:54 PM
Miguel Santana
Miguel Santana's Avatar
SJN,
This valve is the only item from BVM that I do not like cos they use some kind of rubber flapper inside and with the time (not to long) helped with humidity, moisture, ect, they tend to leak.-
A scheader valves like Robart or Spring Air has same automobile heavy duty design inside....and the'll will never give you problem.-
Sorry for been the only one around telling this....
Old 05-31-2005, 08:37 PM
Larry K
I just stick a standard air hose in the valve and fill it by holding the hose in place.
Larry
