 Fuel pump  switch wiring >
Old 08-17-2006 | 05:40 PM
figueroa's Avatar
My Feedback: (22)
Default Fuel pump switch wiring
Hi,
Does any one have a schematic for wiring a 12 volt fuel pump. I would like to use two switches one for power the other for reversing the pump.
Thanks.
jef
Old 08-17-2006 | 07:33 PM
swansons's Avatar
Default RE: Fuel pump switch wiring
Jef,
This is freehand rough but it shows how to do it.
Let me know if you have questions.
John S.
Old 08-17-2006 | 07:42 PM
swansons's Avatar
Jef,
I'll try it again. The scanner got me the first time.
John S.
Old 08-17-2006 | 07:47 PM
swansons's Avatar
Maybe the third time will be a charm...
J.S.
Old 08-17-2006 | 08:19 PM
figueroa's Avatar
My Feedback: (22)
J.S.
Your drawing is just what I was looking for. I will pick up the switches tomorrow.
I appreciate your time and effort.
Thank you.
jef
Old 08-18-2006 | 09:06 AM
My Feedback: (49)
You only need one switch. Get a three position "center off" DPDT switch and wire it as shown in the diagram. Center position is off, one direction for fill, the other way for empty.
Joe
Old 08-18-2006 | 10:10 AM
figueroa's Avatar
My Feedback: (22)
Thanks Joe,
Got all the parts will assemble tonight.
jef
Old 08-18-2006 | 10:14 AM
Jeff,
Yup, Joeflyer is right...You can eliminate the SPST switch, as it disarms the system to prevent the pump switch from being accidentally operated....It's just a safety measure.
You only need the DPDT switch. All other wiring is correct. You can even use a "Momentary" DPDT switch if you prefer, as it won't pump unless you hold the switch lever in place while pumping. "Momentary" switches are spring loaded to the center "OFF" position.
Harley Condra
BVM REP
JetCat REP
