DUCTED FAN JETS
#51
RE: DUCTED FAN JETS
At least http://www.thorjet.co.uk seems to have an F-20 that is good for DF.
Another one I recently found is http://www.pjpjets.co.uk/ . I like the look of their Eurofighter.
#52
RE: DUCTED FAN JETS
Just to add to Pizzazz, the Ramtch requires larger intake area. If you are building a plane with small intakes, stick with the Dynamax. If not, the Ramtech is the way to go.
Mark
Mark
#53
RE: DUCTED FAN JETS
ORIGINAL: mafrasca
Anyone want to build a Skyburner? Follow this link,
http://rccanada.ca/bb/viewtopic.php?t=12987
Enjoy!!
Enjoy!!
New pics and progress to be added to the above thread in the near future!
Regards,
...jim
#54
RE: DUCTED FAN JETS
Hey Jim,
I know you flew one some time ago. Do you have any tips for flying the Skyburner? What take off run did you need? Landing approach?
Cheers,
M.
Cheers,
M.
#55
IL
RE: DUCTED FAN JETS
I have a TGA F-15 III ready for test flight. Several questions. OS .91 - locktite which if any bolts (red or blue)? BVM remote needle - set the high with the screw with the arm in what position, middle or full deflection with more room to richen? Plumed in series now but is this a mistake instead of doing parallel?
Kirk
Kirk
#56
RE: DUCTED FAN JETS
Fellas, thanks for the input. Am wanting to use the unused new gear I've had on hand over all these years. So looks like it's the Turbax with the K & B 7.5 engine in the Thorpe Phantom. The BYRON MIG 15 kit, Byrofan, the Axiflos, Micromold fans, K & B 3.5 D/f engines, Rossi .60 etc, will just have to wait their turn. Thanks again, Glen
#57
RE: DUCTED FAN JETS
ive just finnished building the f20 and have just run the motor up, i will see how my macs 1190 pipe goes when i fly ,(it is really loud on the ground) the tuning seems good with good feel on the needle valve. i measured the static thrust by putting my digital scales against a wall and putting the nose fo the plane against it and throttling up i got 4.2kg. auw is 5.9kg does this sound ok?
cheers greg
cheers greg
#58
RE: DUCTED FAN JETS
I have been interested in jets for ages, and the price of turbines always seems a little too high for the risk involved.
Not to mention the requirements/limitations here in oz during the summer.
So I'm glad to see that DF is still popular, as i would love to build a hawker hunter (if i can ever find the plans i wanted that were for a micromold fan and in a UK mag years ago).
that i might even power with one of the new EDF units that are reported to produce as much power as glow ones do..
ie.
electric viofan
E-Turbax.
Rob in OZ
ie.
electric viofan
E-Turbax.
Rob in OZ
#59
RE: DUCTED FAN JETS
The new EDF units sound interesting, their current price tag is outrageous...... but it will come down I'm sure. However I love the sound of the OS91 engine at full RPM.
#60
RE: DUCTED FAN JETS
Hey Greg,
A thrust to weight ratio of 0.71 sounds OK to me. Any jet having a thrust to weight ratio greater than 0.66 should give excellent performance. By the way how did you set your main mixture?
#62
RE: DUCTED FAN JETS
i thought that my auw would be less but i had to add 200g lead to the nose! maybe i can shift somthing as i hate to add dead weight. as for the mixture setting i have rcji mag all the way back to 2002 and there was a great series of articles called ice life, they were dedicated to building, set up, maintanance and opreation of glow df. i dont have all of the articles but i do have the last 2 which cover all preflight ckecks engine set up/tuning and then flight testing. really great stuff. where did you hear about the 0.66 thrust ratio? any body heard about megatech Q9 glow plugs, as i have a few of these which i got with my os91 so far they seem good. the packet says they are good for high heat environments, high rpm, and df and performance motors.
cheers greg
cheers greg
#64
RE: DUCTED FAN JETS
Any of you guys know how to work out the length of a tuned pipe ?
I know the distance is measured from the glow plug to the start of the large diameter of the pipe, but how far ?
#66
RE: DUCTED FAN JETS
KDHPGA
In my Avonds and BVM F-80 I set the remote mixture control to half travel and set the high, 2.5 turns should be ok as a starting point and then once the engine has started go to full throttle and start closing. I use blue locktite in the backplate bolts. Set the throttle travel so that at maximum there is a little play in the throttle arm, its is not good to have it set till it stops because the throttle arm will break from vibration (ask me how I know). I use the Mcoy N° 9 plug and get more than 15 flights per plug.
It is very important to get a reliable idle, 30 seconds at idle and the engine should power up with no hesitation. This may very well save your plane if you need to do a go arround during landing, if you need to go arround power up slowly but steadily. I use Wildcat 5% DF fuel and set the hi a litlle on the rich side, so far havent had a dead stick landing in more than 40 flights.
With respecto to the tank setup, I use paralel in both planes with a header tank with out problems.
Regards
Eduardo
Regards
Eduardo
#67
RE: DUCTED FAN JETS
Nice to see a few other Aussies interested in D/Fans. To rorrock. Bob, I believe I have the plans for the Hawker Hunter you're looking for. I have access at work where I can copy or enlarge any plan to any particular size. Am willing to find and send you a copy of same. Along with the other D.Fs I've mentioned above, I have a WeMoTec Midi fan, MD 001-5, that I'll get around to using one day. Must admit, tho, electrics don't turn me on like a glo or diesel (from the old school). I intend to enlarge small electric L.O.Plans to suit this motor. Also now have the l.o.plans for the deHavilland Vampire out of the latest RC Model Dlyer mag. Let me know. Glen, up north.
#68
RE: DUCTED FAN JETS
Lets try and make this THE ducted fan forum on the web.
Any building going on post here rather than seperate threads, any links to ducted fan related stuff post here, try and make this forum a database for ducted fan flying.
#69
RE: DUCTED FAN JETS
Does anyone have a spare manual or parts breakdown for a Dynamax fan? I received a fan a couple months ago that is in need of a good cleaning so I'd like to at least partially disassemble it.
Dan
Dan
#70
My Feedback: (42)
NC
RE: DUCTED FAN JETS
Dan,
I'll look tonight. I should have one. Have you checked with Tom Cook at Jet Model Products? He is a very smart guy. His web address is [link=http://www.jetmodelproducts.com/dynamax.htm]Dynamax[/link]. I will look for you in the meantime.
David
David
#71
My Feedback: (10)
RE: DUCTED FAN JETS
ORIGINAL: Xairflyer
#73
RE: DUCTED FAN JETS
ORIGINAL: deltron
I wonder why? It seems there's a category for everything else.
Dan
Dan
Gordon
#74
RE: DUCTED FAN JETS
ORIGINAL: Xairflyer
You could try contacting the newletter editor at http://www.sccmas.org and ask whether the article is still available online somewhere.
Gordon
#75
RE: DUCTED FAN JETS
But, there is a lot of guys doing both (df and turbine) that will still look at it. So, i dont see any probs regarding the 'know-how'...And if you want my opinion about that, there is a lot of turbine jet flier that dont know $%%? about building and setup of jets planes. There's a lot of arf plane, a lot of turbine jet flier have a lot of cash but very little knowledge, but they want to fly jet for the kick or to show that they have $$$. You just have to look of kind of questions posted in this forum, sometimes, it's just ridiculous. Flying jet, in my opinion, should be the top of the learning curve. Not something for big baby with lots of $$$.
