Reload this Page >
1/4 Scale T11 Vampire.
Old 05-29-2007, 03:10 PM
Glen Roberts
Default 1/4 Scale T11 Vampire.
Some photgraphic progress of my 1/4 scale T11 vamp.
Next step, wing and boom moulds.
Glen
ID:	693708   Click image for larger version
ID:	693709   Click image for larger version
ID:	693710   Click image for larger version
ID:	693711   Click image for larger version
ID:	693712   Click image for larger version
ID:	693713   Click image for larger version
ID:	693714   Click image for larger version
ID:	693716   Click image for larger version
ID:	693717   Click image for larger version
ID:	693718   Click image for larger version
Old 05-29-2007, 04:10 PM
Geoff White
Geoff White's Avatar
Default RE: 1/4 Scale T11 Vampire.
All I can is beautifull work!
Old 05-29-2007, 04:13 PM
Mike Emilio
Looks like excellant craftsmanship.
Old 05-29-2007, 05:32 PM
CJ2002
CJ2002's Avatar
Stunning...what a beautiful model.
Dick
England
Old 05-30-2007, 04:38 AM
Brian Borland
Hi Glen
I see you're turning up the heat ...looks pretty good to me. Have you got the fuse jouind yet?
Cheers ... Brian B
Old 05-30-2007, 04:59 AM
Gerald Rutten
Gerald Rutten's Avatar
Hi Glen, beautiful project you have there, realy amazing! Nice to see you going like this.
Very big plane, any chance you will fit this in F4c......?
Very best regards,
Gerald jr
Old 05-30-2007, 09:57 AM
Props4ever
Looking excellent Glen, its craft's man quality job there..
Old 05-30-2007, 11:48 AM
Glen Roberts
Some more of the internal wood work.
Glen.
ID:	694203   Click image for larger version
ID:	694204   Click image for larger version
ID:	694205   Click image for larger version
Old 05-30-2007, 11:50 AM
Glen Roberts
Hi Brian.
Yes the fus is joined with all the internal wood work installed.
Starting with the wing moulds now.
Cheers.
Glen
Old 05-30-2007, 11:54 AM
Glen Roberts
Hi Gerald.
Good to hear from you.
I am hoping they will up the F4C limit to 20Kg's. (I wish)
I am building it to F4J rules, it should come out under 20Kg's.
Cheers.
Glen.
Old 08-29-2007, 04:30 AM
Brian Borland
Hi Glen
Hows your project going? I've made a little progress with my 1/5th single seater. I've pretty much got the wood work all sorted for the fuse. The booms are done and fit nicely and I hope to close up the fuse next week.
All my drawings are a result of reverse engineering of course and as a result there's a lot of fiddling before they get to the computer, however soon it'll be just the wings and tailplane....yipee!
I have all the patterns for the nose leg assembly done and have sorted the steering ...not easy on the little snub nosed single seater. All the nose parts will be investement cast and machined. I had a test set of parts sand cast to check out the way it works. The mains will be a piece of cake by comparrison.
Anyway .... a cople more pics ...I know it doesn't seem like I've done anything! Hope you don't mind of your site?
Cheers ... Brian
ID:	752364   Click image for larger version
Old 08-29-2007, 06:38 AM
Glen Roberts
Hi Brian.
Good to see the progress on you Vamp. The 1/4 scale one is getting there, still a lot of work to go. I am busy at the moment with the wing, stab and boom plugs, should be able to start the moulds within a month.
The gear is at the machine shop (12 sets), all out of bar stock and plate.
Keep up the good work. I will post some photo,s soon.
By the way where are you going to fit your tanks?
Cheers.
Glen.
Old 08-29-2007, 04:59 PM
Brian Borland
Hi Glen
They do take a while!
I'm able to fit two standard tanks (Dubro 32oz x 2) on the floor between the rear bulkhead of the cockpit and the turbine and will have a header between them. All in all it'll give me 2.2 litres which based on what I'm flying at the moment with my J-66 can be anything from 8 mins at full throttle ALL the time to 14 mins at a more sedate "Vampire" style pace.
I have a friend who flies a Sterner Vampire the same size and he says the fuel load ahead of the CG is not a problem ...in fact that's the way I have my Bullfrog set up too and it's fine.
I'm trying to keep everything weighty as far forward as possible and to that end the flight pack batterie(s) will be under the nose cap, the ECU battery under the floor/pilots seat along with the ECU. The RX(s) and air tanks will be behind the pilots back rest ...under those access hatches below the cockpit rails....hence the plywood tray set-up there. At this time the pump, solenoids and filters will be just ahead of the CG adjacent to the turbine. I was considering conformal tanks behind the inlet ducts but I'll go with what I've got for simplicity's sake at the moment.
I also plan to fit plumbing and attachment points in the wings to allow the fitting of overload tanks .... which would be right on the CG. Obviously they wouldn't be dropable but you could sure pack some fuel in two of those....gallons of the stuff in fact.
I'll post a pic of the fuse/boom assembly when I get it to that stage. I hope like hell I sell some!
Cheers .. BB
Old 09-05-2007, 04:41 AM
Glen Roberts
Some more photo's of the Vamp with wing and boom plugs in place to give an idea of the size.
Should start with the finishing of these parts soon and the be able to make the moulds.
All the wood work for these are done, the advantage of using Solid Works and Autocad.
Cheers.
Glen.
ID:	756914   Click image for larger version
ID:	756915   Click image for larger version
ID:	756916   Click image for larger version
ID:	756917   Click image for larger version
Old 09-05-2007, 01:33 PM
AndyAndrews
AndyAndrews's Avatar
You guys are really talented. It looks like a spectacular build. I can't wait to see the finished jet. I can't believe the amount of high quality scratch builds I have seen on the RCU jet forums. You guys rule!
Andy
Old 09-05-2007, 01:36 PM
ThomasP
Hi Glen,
It looks stunning, really nice, any plans for the finnished scheme?
Old 09-13-2007, 09:04 AM
Glen Roberts
Hi ThomasP.
I would like to do it in a U.K. scheme, G-HELV if I can get enough photos and color documentation. I intend to take this model to the 2009 WJM so the documentation has to be right.
Do know of anyone in the U.K. that might be able to help.
We have a silver and dayglo Vamp localy but I am not to keen on it.
Cheers.
Glen.
ID:	762128   Click image for larger version
Old 09-13-2007, 09:33 AM
CJ2002
CJ2002's Avatar
ORIGINAL: Glen Roberts
Hi ThomasP.
Cheers.
Glen.
Glen,
I have 100+ detail pics of this aeroplane - taken at Kemble last year that I'll put on a CD and send to you if you pm me your address. If you decide to do it, I'll find out where it lives and get any further shots/details you need.
Cheers,
Dick
England
Old 09-13-2007, 10:32 AM
Geoff White
Hey Dick,
That was the one that was at Kemble at the weekend. Its owned by Air Atlantique(which I think are based at coventry)????
The website has a bit of background on the aircraft http://www.classicflight.com/
Geoff.
Old 09-13-2007, 11:03 AM
CJ2002
CJ2002's Avatar
ORIGINAL: Geoff White
Hey Dick,
Geoff.
Yes, I'll have a word with Aldridge when he gets back from fraternising with the enemy this w/e to get a contact...he flew for Air Atlantique towards the end of his career.
Meanwhile:
http://forums.airshows.co.uk/cgi-bin...T;f=10;t=38007
...is worth a look.
Cheers,
Dick
Old 09-13-2007, 12:13 PM
ThomasP
Hi Glen,
That scheme willl look stunning.
Old 09-14-2007, 03:27 AM
CJ2002
CJ2002's Avatar
Glen,
CD posted this am first class air mail...if it strays (which sometimes things do when going to SA from me!) let me know and I'll send by a more secure method.
Cheers,
Dick
England
Old 09-16-2007, 05:44 AM
Glen Roberts
Some Solidworks renderings of the gear for the Vamp. Busy at the macnine shop at the moment.
The gear design was done by my son Dylan.
Cheers.
Glen.
ID:	763684   Click image for larger version
ID:	763685   Click image for larger version
ID:	763686   Click image for larger version
ID:	763687   Click image for larger version
Old 09-16-2007, 06:24 AM
marm
that gear looks great! Love to find some like that for a 90mm i have been working on.
Barry
Old 10-03-2007, 02:58 PM
Glen Roberts
Hi Dick.
I have not recieved the CD yet. Probably gone astray.
Some photos of the main gear so far.
Cheers.
Glen.
ID:	775883   Click image for larger version
ID:	775884   Click image for larger version
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
