Carbon fiber where to get it
Where do you get those great looking mounting boards to finish up the insides of jets?
I do have some carbon fiber plank which are a sandwich of carbon fiber and balsa in the middle but they do not have that same great finish that looks like real carbon on a racing car.
http://img182.imagevenue.com/img.php...0_122_13lo.jpg
RE: Carbon fiber where to get it
Hi,
I managed to get some sheet material from Todd at Dreamworks, it was called "Carbon look" just as good, and cheaper than carbon fibre sheet.
Be aware it has also been said that carbon fibre in the fuselage can in certain circumstances sheild radio signals to the reciever arial ect.
Those 'Great looking carbon fiber mounting boards', may be just 3mm ply, covered in stick on CF lookalike plastic. Carbon fiber is rediculously hard to cut, you will need a ceramic tile cutting blade to saw it. Ray
Do you have a web ste for Todd at Dreamworks? (besides the animation/movie studio)
Never mind got it http://www.dreamworksrc.com/
My Feedback: (47)
ORIGINAL: djindivik
Barry
I have ordered some CF look alike from http://www.dreamworksrc.com/ and will give them a try.
Do you laminate them first before cutting the holes or do you make the plywood board first and then match the CF look alike to it?
Most of the time, you can just use the CF look alike by itself. You can always reinforce it in the places you neeed under the board.
HI
We do not have carbon fiber board, but we carbon fiber silk and cloth in stock.
http://www.airpacmodels.com/twe/inde...e4ac5d6607ac1e
My Feedback: (21)
OK
A great place for purchasing laminated sheets of carbon fibre/plywood is
http://dragonplate.com/default.asp
Richard
Richard
