BD-5J Project
#78
MI
RE: BD-5J Project
Hi,
Since there is no instruction CD or anything else for that matter, do you have any construction pictures? Never purchased a plane w/out some reference info. I'm at a loss on some of the construction. The install on the elevator servo looks to be a real trip. I also noticed I have to cut away for the rudder servo. Any help you can give will be much appreciated.
Thanks, Doc...
Thanks, Doc...
#79
My Feedback: (21)
RE: BD-5J Project
Hey Doc.
I've got one of these coming within the next 2-4 weeks. We can can corroboratively do to the build on them and and I think pretty much figure things out for ourselves. Between that and the input of others we should be able to do this.
I am pretty sure that if we say we are going to do it a certain way and some body thinks its stupid they will let us know. Thats how it usually works out for me at my job anyway.
Putting a Jet Central Rabbit in mine. Should work well.
take care!
zonk
take care!
zonk
#80
MI
RE: BD-5J Project
Hi:
That sounds good to me. When I 1st ordered mine from BVM on Friday the 24th of July, the actual order wasn't placed until Monday the 27th. Patty, from BVM, said she was just told the wait time had been reduced from 8 weeks to 6. As it turned out, I didn't receive it uintil October 19th. Additionally, I talked to Jeff in Calif., and was told this would be shipped with a "construction CD". Once I opened the box and it was well packed, I couldn't find the CD. Jeff asked me again to re-check which I did. He then emailed John from the factory and was told they are still working on the CD. So, with all that being said, issues have come up such as the servo opening or the lack of one in the rudder. You can tap it and hear there is a hollow spot. I emailed John direct and eh sent me the rudder drawing which shows where to cut the opening. The big concern is where they have you install the elev. servo. It's all the way back inside the rear of the fuse. It's tight but there is probably enough room to screw down the servo once you drill the 4 holes. They supply a carbon rod to attach to the servo arm but I'm lost from there. As far as the wings go, there is already a cut opening but I'm not sure if that is just for the alerions or for another servo for the flaps. This should be interesting to say the least. I guess I have been spoiled spending much time on the Boomerang and Sprint build threads for the past 2 years. Many pictures and lot's of knowlegable people to help make it good. At least the Boomeranges have Instructions. Much of the hardware is still a mystery on the BD-5 but IT WILL GET FIGURED OUT. Look forward to working with you on this.
Doc...
Doc...
#82
RE: BD-5J Project
I also just order mine last week not realizing that there are no instructions included and I will be watching closely for any info posted
Cheers,
Frank
Cheers,
Frank
#84
RE: BD-5J Project
I was told 5-6 wks in the Coors scheme with out lettering I will be making my own,hopefully between us we should be able to figure the instruction dilemma plus I have a few mod ideas from what I have seen.
What turbine do plan on using I am still up in the air,it looks like any 13 -22lb will work.
Frank
Frank
#85
MI
RE: BD-5J Project
Hi Frank:
Mine took 11 weeks....but it was worth it. I was orriginally told there was an instruction video. None. I talked to John in China and he has sent me some usufull pictures. The issues I have are in the elevator and rudder servo instal. I'm making modifications with servo covers which will work fine. I will be doing pictures and will release when the time is right. This is a great flying ship and will be better down the road.
Doc...
Doc...
#86
My Feedback: (28)
OH
RE: BD-5J Project
ORIGINAL: moki180
Frank
Frank
#89
RE: BD-5J Project
Hello Doc, we met again, how have you been?
I received mine on the 28th of December last year, so it was an excellent Christmas-new years present
I haven't started it yet, except from trial fitting everything. I also had the same questions as you have but I have put the model aside due to other projects. I shall be starting it soon though and we can exchange ideas and information here.
Originally my one came with small elevators, about 3/4 the span of each tailplane. After 3 months I was contacted by John by email saying not to attempt to fly the BD-5 until I have received the new tailplanes. Soon afterwards I received the new tailplanes, painted in my colors ( pepsi ) and now the elevators are full span of each tailplane half.
I am going to use my P-60. I talked to Anton about the power plant at Jetpower and he said to use nothing more than a P-60.
Paul
Paul
#90
RE: BD-5J Project
What is the reasoning for not using a bigger turbine ,I understand the thrust issues with the plane which should be able to mixed out mostly in today's radio systems all I am trying to do is get the plane up to flying speed quicker which should equate to shorter takeoffs on grass strips.
Frank
Frank
#91
My Feedback: (21)
RE: BD-5J Project
ORIGINAL: moki180
Frank
Frank
Does anyone know of structural issues?
I'm looking to see mine almost any day now.
#92
RE: BD-5J Project
I understand your concerns about grass field operations. I'm just letting you know what the manufacturer suggests. Yes the main reason is because the thrust line is quite high up. Also my friend Trevor Skedge in the UK flew it with the P-60 and he reports that the pitch change with thrust is present even with the p-60. I would also like to install something a a little more powerful.
Paul
Paul
#93
My Feedback: (28)
OH
RE: BD-5J Project
The only issue I had on the byron with the rabbit was takeoff, had to hold full evelator at the start of the takeoff run to get the nose to lift from the thrust line. Other then that there was no problems at full throttle.
#94
MI
RE: BD-5J Project
Hi Paul,
I can only assume that since I received mine a month ago that problem has already been solved. I'am making several mods on mine. I do not like the way the rudder servo is supposed to be installed so I have made a servo hatch for that. The Elevator install looks tough so I'm making servo hatched for both the right and the left. I'm undeceided in the flaps right now. I'm doing picture documantation on every step of the way which will help some one down the road. Keep in touch.
Doc...
Doc...
#95
RE: BD-5J Project
Has any one looked at the indecent of wing or stab when the plane sits on its gear to correct the take-off problem ,also would a full flying stab like the real one change anything?
Frank
Frank
#96
My Feedback: (23)
UT
RE: BD-5J Project
Zagzoo, I have the same issue with mine. I take off with 1/2 flaps, high rates and full up elevator until the plane breaks ground. The first time was very nerve racking as I would normally never hold full up elevator on a takeoff roll, but the BD5 just rolls along and takes off when it is ready and then I relax the elevator and off she goes. I have to put smoke it it this winter, that is the only thing that is missing.
#97
My Feedback: (28)
OH
RE: BD-5J Project
ORIGINAL: moki180
Frank
Frank
#98
RE: BD-5J Project
Hi guys: greetings from Panama city, Republic of Panama. I got my BD-5 from Extreme Jets a couple of months ago. It was sent from China to Miami and then to Panama with JAMES BOND "OCTO*****" color scheme. Very nice work.. No instructions either. Also I have a King Tech 80 waiting for me to finish this jet. I have done all the hinging. My own invention for the nose gear servo and also the elevator rod system, and the retracts are working fine. I will try to send some photos, but because it is the first time uploading them, please be patient. I don't think I will have any problems finishing this jet, but I will appreciate anyone telling me where in hell does the rudeer servo go, on the fin(not to wide for a servo)or in the fuselage with a long N-rod, o.k. lets see if I can send the photos at least 2 by 2. Hope we can exchange info aapanama
#99
RE: BD-5J Project
can someone explain to me how does one upload photos for this site?????
I have tried and tried and nothing.. I can't see my James Bond BD-5 photos
aapanama
aapanama
