Weatronix RX mounting question
Hi,
I was wondering how you guys are all mounting your weatronic RX's? In the manual it states the best solution is to mount it on sponge rubber but I am sure I have seen examples where it is simply mounted on the radio plate hard i.e just using screws into the wood.
Thanks for any advice.
Geoff.
Geoff.
RE: Weatronix RX mounting question
Hi Geoff
On a jet I use servo grommets and long servo screws. On my Prop/ Petrol planes I take more precaution by isolating the plate to which they are mounted to on rubber mounts.
Regards Al
Regards Al
Hi Geoff,
I've mounted mine by setting it off the plywood radio plate on 5-6mm silicone fuel tube 'spacers'.
Seems to work fine.
Regards
Roger
Seems to work fine.
Regards
Roger
Hi Geoff, I screwed mine to plywood webbs glued between the inlet ducts. This makes it handy for routing the aerials, one goes down into the nose in a plastic snake and the other down the left hand wing , again in a plastic snake. Havn't yet had a failsafe frame registered.
m
ps have a good xmas and new year.
m
Cheers Miick,
I was also expecting you to reply. You are so predictable
And Merry Xmas to you as well
Geoff.
P.S. Christmas and New year is going to be spent building a new Flash
Geoff.
1 Post
Grommits Geoff, grommits, though I have mine mounted on some 1/4 inch self adhesive foam because I didn't have any grommits to hand at the time, wheres' Wallace when you want him ?
Ian B
Ian B
I'm back on the Hawk at the moment Geoff, so I'll probably be picking your brain soon. Take no notice of Ian he's probably drunk!
m
m
I went to B&Q and bought a small (about 2 inch by 4 inch) sheet of sticky back felt. This is about 3mm thick and is stiff but may (or may not) give a little bit of damping. I cut this into two strips and stuck this to the radio tray then mounted the Wea.
Whatever you do I think it needs a stand off of some sort to allow cooling to the back of the unit.
Geoff - another Flash? Thought you already had one??? Does it mean you are really into Flash's now and you're going to let me fly you're Bandit while I'm back?????????
ORIGINAL: Roger Suckling
Hi Geoff,
Seems to work fine.
Regards
Roger
Hi Geoff,
Seems to work fine.
Regards
Roger
regards
