What do you think of FORMOST 150 ?
#651
RE: What do you think of FORMOST 150 ?
Hi Instructor
Nice, I like a lot the speed break. Is it efficient?
With turbine are using? Do you have more pic. of your plane?
Thanks a lot
Thanks a lot
#652
My Feedback: (16)
Hi Igorcar,
If I had a chance to do it again, I think I would make the speed brake a little longer and wider. They do help a little. I am using a Jet Cat P-80 dialed back to 16 pounds of thrust. I found out if I do a slow fly-by and then make a landing, the speed is real low. It makes more sence to land out of a 40 MPH slow flight than a 70 MPH fly-by. As soon as I can get a chance, I'll take a few photos and send them to you....
#653
Hi Instructor
Who bigger do you think it shod be?
Whit servos do you use on the flaps?
I going to stick a JJ1800 what do you think?
Thanks and I’m looking forward for the pic.
#654
My Feedback: (16)
I would make the speed brake at least 5 inches long and 2.5 inches wide. How much thrust from JJ1800? I am using a JR 821 Digital servo with 72 inch oz of torque on each flap. They only go down 35º because of the bevel on the leading edge......
#656
Hi guys
The JetJoe1800 is a 20Lb, and what do you think of the foam like on the wings? And what about the ruder?
In the ruder I think it’s good!
Thanks guys.
Thanks guys.
#658
Hi RCISFUN
O thanks I got de PDF.(Can you send me the CAD file?) And do you have more thinks to help me?
About the foam, I think it will be good of about 20 flyits [&o], than starts to come apart. What do you think?
But in the Ruder I think it’s a good idea but with the plywood!
#660
Does someone have a copy of the Formost upgrade which was on the Digitech website?
I`m thinking of buying a Formost 150 as first jet trainer but want now what the upgrade is all about.
Thanks in advance.
Best regards,
Berto.
teh BosModelAir team
www.***************
Thanks in advance.
Best regards,
Berto.
www.***************
#661
My Feedback: (44)
Jets2
Holy Smokes, A 120 SE in a Formost [X(]
Did you make the mods....I hope
What fuel tank is that, and what is the capacity?
How does it fly with that much power?
I was thinking of stripping all of the covering and glassing the wings and stab this winter then doing a paint job, it amazing how much that changes the look.
Yours looks awesome.
Berto
Send me you e-mail address I can send the Original plans that Nicolas drew up and I can send you my plans.
Rich
Berto
Rich
#662
That the bad part. I saw the pic. it is nice.
Are you going to Lake Wales?
And my kit is arrives next week!
But im cuting the parts and geting everything ready!
#668
Can I cut the part as they or on the PDF file?
Im not finding the sullivan tank. im thinking on puting 2 dubro tanks one 60oz on top the 32oz do you know if it fits?
And come on stop working
#670
Im going to put a JJ1800. and I have a JetCat p60 but it is on a F16 JL 1/8.
And im looking foward to buy a P70 im thinking.
#672
NC
it is a custom made fuel tank.
holds about 90oz.
their is a 32oz smoke oil tank under the fuel tank.
The airplane flies great.
holds about 90oz.
#674
ORIGINAL: JKEpps
Hey guys, as an alternative method for strengthening the wing, how about filling it with foam like these guys did for the Cessna 310 that kept having wing failures? I'm thinking of putting a gas engine in y 150 for the time being.
-Jorden
-Jorden
[link]http://www.rcuniverse.com/forum/m_5002875/mpage_110/key_/tm.htm#7836675[/link]
