turbine battery
turbine battery
what mah li-ion battery should I use for an Artes super eagle so I can get at least get a few flights on it, I had a 2100 on my behotec 66, 2 flights safly is all. And do I need 7.4 or 11.1 volt for Artes?
RE: turbine battery
well, thats the way it is, 2 safe flights, I was running a thunder power battery from my trex 450, retired from heli, it was old. But still worked, just on mah anymore. I just need suggestions of what I should run, if 2100 is enough on p-120 then I will go with a 2400 I have but it is 7.4v, is this voltage right for Artes?
My Feedback: (18)
RE: turbine battery
I use a 7.4V Li-Mn 2200 Apogee pack on my Super Eagle. Can safely get about four flights out of it. You can charge those at 2C so they can be charged in about twenty minutes.
Marty
Marty
AB, CANADA
RE: turbine battery
If it uses the FADEC, then a 2 cell would be the right size. I have a 4400 Polyquest on one of my turbines, and theoritically can get 15 fligths between charges...run out of daylight first, so it goes on an overnight charge anyways...
My Feedback: (80)
CA
RE: turbine battery
Hit the link and order a 5200 relion and an "ION" charger.... Fly all day long period... All of my friends and I use em in everything from 3K Boomers to 30K scale ships...
[link]http://www.fromeco.org/[/link]
RE: turbine battery
yea, I like fromco, I run there stuff in all my helis, in my big gassers and I have an ion charger so I don't need another one. The cube would be nice but don't need it.
My Feedback: (309)
CO
RE: turbine battery
So you haven't purchased the turbine yet?
I bought my Artes Eagle from TBM, and it came with a 5600mah Li Ion battery. I'm guessing yours will come with a battery also.
Jim
Jim
My Feedback: (34)
ON, CANADA
RE: turbine battery
ORIGINAL: R/CBOONE72
I have many hours on my 66 with Kero Start which uses on average of 300mAh per flight and I am using a 2,100 mAh LiPo battery and I get 5 flights with 700mAh spare capacity left every time. It seems your battery is defective and not the Behotec 66.
