Reload this Page >
YA F-18 Owners, side rail and steering solution
Old 03-29-2008, 04:32 PM
seanreit
My Feedback: (60)
seanreit's Avatar
Default YA F-18 Owners, side rail and steering solution
Here's the long awaited solution, upgraded side rails that come ready to fit and steering arm solution.
$100.00 for the side rails, $30.00 for the steering arm. Plus shipping.
Buck, this is yours and it will go out early next week, and Billy, your order is complete, let me know if you want the steering arms.
PS, this is mocked up, the set screws will be flush when we get them.
ID:	916755   Click image for larger version
ID:	916756   Click image for larger version
ID:	916757   Click image for larger version
ID:	916758   Click image for larger version
ID:	916759   Click image for larger version
ID:	916760   Click image for larger version
ID:	916761   Click image for larger version
Old 03-29-2008, 04:36 PM
seanreit
My Feedback: (60)
seanreit's Avatar
Default RE: YA F-18 Owners, side rail and steering solution
Joe, the rail the plastic bushing rides in on yours has been slightly modified, let me know if you want to upgrade. Special price for you bud.
Old 03-29-2008, 04:50 PM
cactusflyer
cactusflyer's Avatar
Very nice work Sean! You are truly becoming a Jedi!
Tailwinds,
John
Old 03-29-2008, 04:59 PM
SDCrashmaster
SDCrashmaster's Avatar
Nice work Sean. That sure looks like a solid solution.
In looking at your photos, I need to shout out to all those who have, or are waiting on gear detail from me...the steering arm that Sean shows above will interfere with the detail work on the nose gear.
My upper detail sleeve goes up halfway between the two set screws that secure the pin in the top of the nose strut. Just a head up.
The top of the sleeve almost reaches the side rails. (see pic)
Paul
Old 03-29-2008, 05:04 PM
seanreit
My Feedback: (60)
seanreit's Avatar
Paul, can there be a solution based on your work to integrate the solution Joe came up with? If so, how would you propose to do it?
Can you draw an idea up?
Old 03-29-2008, 05:34 PM
SDCrashmaster
Not sure without seeing exactly where you have positioned your tiller arm.
It appears you're only contacting the aft circumference of the strut. It may be possible to remove a upper rear section of my upper detail sleeve to facilitate using that tiller arm.
Overall shortening the sleeve to only go up to the tiller arm would not look good at all. It's already marginal from a scale "ground level" angle (as far as the detail dissapearing up into the well).
Might not be as noticeable if the front of the detail work was still there.
The upper detail tube must slide down from the top during assembly (along with the uppermost retaining ring with set screw), so the tiller arm would have to remain detached until the last step.
The reason it all has to slide from the top down is because the struts very lower end is painted, and that paint thickness will not allow any of the components to slide on from the bottom.
The tolerances are so tight that even the smallest deformations to the strut from set screws, burring from the retainer rings set screw bores, etc. immediately inhibit the free movement of the components up and down the shaft. This is such a probelm that I have lately been painting the nose strut and detail fully assembled.
Can you post a pic of the arm area close up, in relation to the two set screws it the top aft end of the strut? Does your strut rotate 180˚ in the trunion, or are you still utilizing the stock tillers as an anti-rotation device?
The further I look at your pics, I'd say that the detail going up only as far as the base of your tiller appears the only solution.
Long windidly yours,
Paul
Old 03-29-2008, 05:53 PM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
[sm=thumbup.gif][sm=thumbup.gif]
awesome
Old 03-29-2008, 06:02 PM
Billy
My Feedback: (15)
Nice job Sean!!! Count be in on the steering arm too. Can it be welded on or is the set screw thing pretty strong? I will collect the rest of the guy's money next weekend. I'll send you the check then. Thanks for all the work you put in.
Hey what size are the holes in the arm? Is there enough meet to tap a 10/32?
Billy
Old 03-29-2008, 06:36 PM
seanreit
My Feedback: (60)
seanreit's Avatar
It's double tapped 4-40 right now. I gave it the ole hand pull test and it was pretty stout. If you want to increase it later, my all means, go ahead, but I'm pretty happy with it myself, if it was mine, I'd fly it.
Old 03-29-2008, 07:28 PM
Joe McBride
My Feedback: (12)
Joe McBride's Avatar
Nice job Sean! Paul, from your pictures and Sean's it doesn't look like a conflict. It looks like the tiller arm can be "set" comfortably above the scale piece you make.
Joe
Old 03-29-2008, 07:51 PM
SDCrashmaster
It looks that way but, upon retraction, my detail work is only 1 millimeter from the side rails.
I can't really tell exactly where he has them in the pics, but on the detail work, I have an access hole about 1/8" below the top edge of my upper tube to access the lower of the two upper pin set screws.
In studying his pics closer, it may not be as intrusive as I thought...might only require cutting of the top 1/8"-1/4" of the detail.
Also, Sean's pic looks like Gen1 gear based off of the oleo (like your first ones Joe) so I may be looking at oranges and comparing my apples to them.
P
Old 03-29-2008, 09:39 PM
scaleMan
My Feedback: (92)
from Sean's pictures and looking at my nose gear, it sure looks like it will fit on there without modification..... Id like to get a set made up for my nose gear Sean if possible... thx Greg
Old 03-29-2008, 09:50 PM
seanreit
My Feedback: (60)
seanreit's Avatar
PM me for orders if you don't mind, and I'll get anyone set up.
Old 03-29-2008, 11:00 PM
Boomerang1
Boomerang1's Avatar
Lovely job! Is the steering arm designed for a mechanical linkage or cables? - John.
Old 03-29-2008, 11:10 PM
seanreit
My Feedback: (60)
seanreit's Avatar
Only cables, if anyone wants to invest in direct drive for this airplane, please let me know, I have at least one option for less than $250.00 that is very robust.
Old 03-29-2008, 11:55 PM
SDCrashmaster
Well,
If Greg thinks it will work out, then we'll let him determine whether the detail will get in the way.
I really hope so because it sure looks like a much improved set-up.
Sorry to step on your thread with the red flag action Sean.
As always, you da mang!
Paul
Old 03-30-2008, 12:15 AM
NickC5FE
My Feedback: (31)
NickC5FE's Avatar
Nice work Sean! I just may have to get a set for my Bug. You work really quick with awesome alternatives.
Old 03-30-2008, 12:16 AM
Boomerang1
Boomerang1's Avatar
Sean, on the steering arm you show, the holes for the cables are not in line with the centre pivot for the leg. Will this result in the cables pulling unevenly or have I missed something? John.
Old 03-30-2008, 01:15 AM
cactusflyer
Hey Paul,
Did you ever consider doing an A-7 nose strut in, oh, let's say 1 /7.5 scale?
Gorgeous work to say the least!
Tailwinds,
John
ID:	917191   Click image for larger version
ID:	917192   Click image for larger version
ID:	917193   Click image for larger version
Old 03-30-2008, 04:58 AM
lavi rider
Paul..
I think that there's a major problem with this persons solution ...When viewing the part it is clear that the F-18's strut retracts forward this means that upon retraction the control cable will be pulled significantly forward.
Peter.
Old 03-30-2008, 05:48 AM
Boomerang1
Boomerang1's Avatar
Usually the servo is mounted forward of the retract in a forward retracting unit. The cables go slack as the wheel retracts. - John.
Old 03-30-2008, 07:44 AM
grbaker
My Feedback: (29)
grbaker's Avatar
Do these pics answer your question?
ID:	917325   Click image for larger version
Old 03-30-2008, 08:25 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Sorry guys, I guess you had to take the other thread and mash it with this thread in your head! Thanks to Gary for straightening that out for me
Old 03-30-2008, 11:53 AM
Shaun Evans
Shaun Evans's Avatar
Sean,
Nice, bro. I'll take one of the arm! I'm going to hook it straight to the cable, but with the servo in front of the gear. See any problems with that?
Old 03-30-2008, 11:59 AM
seanreit
My Feedback: (60)
seanreit's Avatar
Nope, no problem, PM me.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
