Reload this Page >
Safety wire or Tie wraps?
Old 06-05-2008, 08:11 AM
Sparhawk
Sparhawk's Avatar
Default Safety wire or Tie wraps?
Just wondering what you all prefer with regards to securing your fuel lines. For fuel tanks, I always solder on Dubro barbs so that the pickup line will not fall off in the tank and back it up with a small tie wrap. But for places where there is just a fuel tube on a straight brass/copper tube or fitting, which is best?
Dan
Old 06-05-2008, 08:24 AM
747drvr
747drvr's Avatar
Default RE: Safety wire or Tie wraps?
Double wrapped safety wire secures the fuel tubing more evenly around the circumference of the tube . Tie wraps have been known to actually pull the fuel tube away from the brass tube near the receiver .
Marc
Old 06-05-2008, 08:34 AM
Gordon Mc
Yup - I totally agree with Marc.
Old 06-05-2008, 10:51 AM
DanSavage
DanSavage's Avatar
ORIGINAL: Sparhawk
When I was running fuel airplanes, I used to flair the end of the metal tubing a little bit, then wrap a couple of turns of safety wire to act like a hose clamp.
Old 06-05-2008, 10:56 AM
causeitflies
causeitflies's Avatar
I always make a barb out of larger tubing then safety wire.
Old 06-05-2008, 11:10 AM
drdoom
My Feedback: (9)
Safety wire.
Old 06-05-2008, 12:28 PM
dbarrym
My Feedback: (47)
dbarrym's Avatar
Safety wire - I have seen leaks caused with tie wraps, they do not apply even pressure all around the circumference of the tube.
As the fuel or air tubing hardens with age, the point where the tie wrap strap enters the tie wrap 'head' (or whatever) causes the tubing to bunch up/loosen and will often leak.
Barry
Old 06-05-2008, 12:33 PM
invertmast
My Feedback: (23)
invertmast's Avatar
safety wire here..
Old 06-05-2008, 01:06 PM
Sparhawk
Sparhawk's Avatar
Thanks for the replies guys. I will continue to use safety wire, and include the tank internals from here on out. I will use the tie wraps where they work they best - wiring looms.
Dan
Old 06-07-2008, 11:48 PM
gooseF22
gooseF22's Avatar
no question safety wire here. only time Ive used tie wraps is on tygon or glow, but I flare the pipe. as I replace line, I safety wire now. I had a leak I couldnt find until I replaced the tie in the tank. that was a long troubleshooting process on a gasser. it kept getting bubbles.
made a believer of me.
g
Old 06-07-2008, 11:54 PM
sweetpea01
My Feedback: (10)
where are you getting the safety wire from?
Old 06-07-2008, 11:58 PM
gooseF22
gooseF22's Avatar
todd at dreamworks, pliers too.
Old 06-08-2008, 12:22 AM
invertmast
My Feedback: (23)
invertmast's Avatar
ORIGINAL: sweetpea01
Work I "borrow" it from time to time...
Old 06-08-2008, 07:10 AM
joeflyer
My Feedback: (48)
You can buy safety wire at almost any hardware store.
Joe
Old 06-08-2008, 10:35 AM
Tom Antlfinger
My Feedback: (24)
Tom Antlfinger's Avatar
I use the fine stuff BVM packages for my air lines, but on the fuel lines, I use heavier .021(0.53 mm) aircraft stainless steel safety wire........perfect for tight wraps on clear PE tubing as well as Tygon......works best when wrapped with a locking safety wire pliers.......
I got my roll(sold by the pound) at the EAA Flymarket several years ago.....Packaged by Wire and Cable Specialty Ties, Inc. in West Chester, PA......PN#302-21.....1 lb spool will last a lifetime
Old 06-08-2008, 11:55 AM
AndyAndrews
AndyAndrews's Avatar
Saftey Wire ALL the way, get it from Todd at Dreamworks if you can't find .020 "soft" SS wire. The problem with tie wraps "zip ties" is that they don't secure 360 degrees around the tubing. There is a slight gap that can't be tighened where the tie connects to itself.
Andy
Old 06-08-2008, 12:32 PM
sweetpea01
My Feedback: (10)
Thanks for the info
