 CARF Flash Flap issues >
Old 08-22-2008 | 12:22 AM
dubd's Avatar
Default RE: CARF Flash Flap issues
ORIGINAL: Misha Javornik
Hi Raf, are you using the full ducting on this jet? are you using the stock pipe ? can you post a picture of your turbine install?
Thank you
Misha
Here is a pic of my turbine install (P-120SE), which is exactly the same as Raf's Titan SE install. We're both using the stock pipe.
BTW - The Flash locked in on landing with 40mm of flaps. No more PIO!
ID:	1016516   Click image for larger version
Old 08-22-2008 | 10:30 AM
ravill's Avatar
Like Dantley (I think he goes through more avatars than....I don't know! ) showed, we don't need no stinkin' ducting!
Raf
