Reload this Page >
UT-160 turbine? Feedback please?
Old 12-08-2009, 03:30 AM
  #76
chrigui
chrigui's Avatar
Default RE: UT-160 turbine? Feedback please?
Many thank Gerald
this is the data reading
not 120.000 due lack of fuel in a festo join
my next test is with exaust cone like yours...
i think to put the engine in a PST F-84G
Old 12-08-2009, 10:03 AM
  #77
erazz
Very nice work chrigui.
Excellent workmanship!
The numbers are very good. You should have a very nice running engine.
Are the readings taken with the cone off? If so they may be slightly high. As a rule you should try and keep the EGT (cone on) to 650c or below. Anything over will reduce bearing life and increase chances of turbine failure.
The c.c. also shows signs of "late" (e.i. rearward) burning - you can see that the front part was cooler. You might want to try to block some of the holes in front. Also try to bend the injector needles to the side so the fuel contact the vaporization tube as soon as possible. These changes should help reduce the EGT.
Keep on posting!
Old 12-08-2009, 12:19 PM
  #78
chrigui
chrigui's Avatar
ORIGINAL: erazz
The c.c. also shows signs of ''late'' (e.i. rearward) burning - you can see that the front part was cooler. You might want to try to block some of the holes in front. Also try to bend the injector needles to the side so the fuel contact the vaporization tube as soon as possible. These changes should help reduce the EGT.
Keep on posting!
hello...
the numbers are taken with cone "on" and i think that are good
i burned over 20 litres of kerosene
Old 12-08-2009, 02:55 PM
  #79
Gerald Rutten
Gerald Rutten's Avatar
Indeed good looking numbers, you might even tweak the cone more with those temps. First see what you have at max rpm.
Best regards,
Gerald
Old 12-09-2009, 02:02 AM
  #80
chrigui
chrigui's Avatar
i will try another cone like your..
now i must to test the reliability for secure use on model...
Old 12-09-2009, 03:28 AM
  #81
erazz
ORIGINAL: chrigui
ORIGINAL: erazz
Keep on posting!
hello...
the numbers are taken with cone ''on'' and i think that are good
Hi,
If so then the numbers are very good
Great to see more turbine builders here.
Old 12-09-2009, 03:38 AM
  #82
chrigui
chrigui's Avatar
many thx....
this is a long time work start one years ago, stopped due to crisis in my factory , then
re-started 2 weeks ago ...
Old 12-12-2009, 11:16 AM
  #83
chrigui
chrigui's Avatar
today new test with fuel tank revised
rpm trust temp.
120.000 16,2 / 16,5KG 707°c
Old 12-12-2009, 03:09 PM
  #84
erazz
ORIGINAL: chrigui
rpm trust temp.
Nice thrust but the temp is a bit high. The bearings can suffer with this heat.
You can either open up the nozzle, tinker with the c.c. or just limit the RPM.
Don't sweat it. Building turbines is like that. The tinkering never ends
Old 12-12-2009, 03:24 PM
  #85
chrigui
chrigui's Avatar
this is the high temp reached during today test
other value was 687° - 672°....the nozzle is little closed in diameter than original design
Old 12-16-2009, 08:02 AM
  #86
chrigui
chrigui's Avatar
here in the KERO START version
Old 02-14-2010, 07:27 PM
  #87
Jetbono
Hey Man , You got a seriously good looking engine, keep up the good work , its an inspiration for some of us ..
What bearings do you run on your engine ?
Old 02-14-2010, 07:33 PM
  #88
Jetbono
What Dia compressor are you using ?
Old 02-15-2010, 01:56 AM
  #89
chrigui
chrigui's Avatar
70 mm diam.
Old 02-19-2010, 12:55 PM
  #90
Jetbono
Hey  All
Im currently building a KJ66 style combustion chamber , does anybody know where I can get Inconel vaporizer tubes ?
Also Which Grade inconel is best to use, 718 or 625 ??
Old 02-19-2010, 01:13 PM
  #91
Gerald Rutten
Very close to you....: http://wrenturbines.co.uk/accessorie...mebuilderparts
Old 02-19-2010, 02:25 PM
  #92
Jetbono
Ahh right , Great ..
Old 02-21-2010, 07:01 AM
  #93
Jetbono
What is the best way to make the combustor ends such as in picture bellow ?
Press or Spinning ?
Whats best ?
Old 02-21-2010, 07:13 AM
  #94
chrigui
chrigui's Avatar
i used a press ..
Old 02-21-2010, 08:40 AM
  #95
Gerald Rutten
Depends on how much you wanna make. For small amounts spinning is a good option as I do, making lots of them you better make some moulds for a press.
Below some pictures of my spinning method, just one of the way's to do it.
(In this case spinning a MW54 chamber)
Best regards,
Gerald
Spinning mould making:
Drawing of multifunctional mould:
And here the larger one for my GR180, bit simular to the ones here:
Old 02-21-2010, 11:22 AM
  #96
Jetbono
Gerald You are good man ..
I love your work ...
I wish I could have your talents ..
Thanks for your help everybody ..
Will try to make mine too hahaha
Old 02-21-2010, 11:28 AM
  #97
JKEpps
JKEpps's Avatar
I agree with Jetbono!
I went to your website! Sorry about the drool all over your webserver! LOL! Those pics of your work had me wanting to do the same thing you are. If only I had the equipment, the skills, the time, the money, ... LOL!
Maybe one day. Keep up the good work and I wish you much luck and success!
-Jorden
Old 02-21-2010, 12:13 PM
  #98
Gerald Rutten
Many thanks!
Cheers,
Gerald
Old 02-21-2010, 01:07 PM
  #99
chrigui
chrigui's Avatar
i use one of this machine
Old 02-21-2010, 01:11 PM
  #100
Jetbono
Wow thats industrial press .. Howmuch pressur do these generate ?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
