DTE Source
One consideration may be that JetCat engines require(?) twice as much oil as Wrens or Jet Central engines. But I have heard of engines coking up on some turbine oils. So, ...??
My Feedback: (60)
If you are using a high grade turbine oil that does not coke up as much as others, why not spec a higher oil content to better lubricate things that are spinning really fast??
Keep in mind Jetcat has a reputation to uphold, just like BV or any of the other manufacturers that are trying to put out the "best" product out there. Oil, like a lot of other things in this hobby has different properties the more you spend. (at least in some cases, obviously there are always exceptions to the rules).
It almost always pays out to use what is spec'd out by the manufacturer and distribution centers. If it is a cost issue, yous guys are in the wrong hobby [sm=greedy.gif]
If it is a health issue, well, I bought a sanding bar the other day that is known to cause cancer in the state of California
My Feedback: (13)
ORIGINAL: jetpilot
I used to get coked up. I knew it was bad, but i didnt know it caused cancer!!
Scott
Scott
[sm=shades_smile.gif] LOL OMG! That was a good one[sm=stupid.gif]!
#31
the Oracle intoned...
Make up your own minds and move on.
snip /whack...
ANY QUESTIONS?
snip /whack...
ANY QUESTIONS?
#32
NM
That's good enough for me !
Looks like it will be Mcmaster.com, and DTE from now on for me.
And running only a small turbine myself, the gallon size container is definitely more convenient.
... zak
... zak
#33
TN
Can anybody provide a list of the "clean and green" oils that are acceptable for turbine use and available in the USA? This could be any 2 stroke, 4stroke, and turbine oils that are less of a health hazard.
Thanks.
Thanks.
#34
I started [link=http://www.rcuniverse.com/forum/m_6420192/anchors_6420192/mpage_1/key_/anchor/tm.htm#6420192]this thread[/link] over a year ago. What do you mean by "clean and green"? We can't use old french fries oil from Mickey D's or Burger King if that's what you mean.
#36
GJr. replied ...
I meant clean bill of health for turbine users and green as environmentally friendly. I guess it means non toxic to us and the environment.
#37
NM
" Notwithstanding JetCat being the odd one out at this point in terms of official endorsement, every other flavor of miniature turbine we typically use are completely happy with the stuff. " - MrMike
" I will talk to Bob ASAP to see if anything has changse with regard to oil requirements from JetCat
_____________________________
Matt
JetCat rep "
I guess he's still checking ?
... zak
Matt
JetCat rep "
... zak
