Reload this Page >
Der Jet Model new product F-9f8 cougar and video
Old 09-22-2012, 10:10 AM
  #151
tow
tow's Avatar
Default RE: Der Jet Model new product F-9f8 cougar and video
I`ll look into it and come back to you. Thnx
Old 02-25-2017, 11:53 AM
  #152
Neil Guildford
I've recently bought a second hand Der Jet Cougar and have installed a Jetcat P140 RXI B. Can someone please assist me with the correct CG location? I'm also keen to hear how much flap and what elevator movement/mix is required.
Thanks, Neil
Old 02-25-2017, 01:43 PM
  #153
Dave Wilshere
Neil
Sorry I never found a manual, but balance is not critical and since the set up is basically the same it won't have moved far. The valves are pump were above the 160SX, so much the same as your 140. Movements as I said you need as much elevator and aileron as you can get, it will be obvious from servo slots the limit.
Flap I had around 60mm at the flap aileron joint, only 25mm on fuselage flap. Up mixed with landing flap was around 9mm.
Dave
Old 02-25-2017, 02:25 PM
  #154
Neil Guildford
Thanks Dave.
Old 02-25-2017, 02:37 PM
  #155
tow
tow's Avatar
I do have the manual as a PDF document. Unfortunately I can`t post it here. Do you have an e-mail adress?
Old 02-25-2017, 03:06 PM
  #156
Neil Guildford
Thank you, that would be great. I've just sent you a private message.
Old 04-16-2017, 11:02 AM
  #157
Neil Guildford
This is a super plane, looks great in the air and on the ground. CG and control throws worked perfectly.
ID:	2210083   Click image for larger version
ID:	2210084   Click image for larger version
Old 04-16-2017, 12:44 PM
  #158
tow
tow's Avatar
Looking great! I belive you are happy with the maiden!
Old 06-08-2018, 05:03 PM
  #159
Jetmodeler
Another DerJet Cougar found and doing what they do best, just test flew my new Cougar, found new in the box last year by Ken Olsen, now I have it flying. Forgot just how sweet the DerJet Cougar is, fun machine.
Old 07-02-2018, 12:16 PM
  #160
BluFox
My Feedback: (10)
Default DerJet Cougar
t news and great to hear ! ! !
Can you post some pictures for us to view>
Eric Clapp
Der Jet Models USA
authorized dealer
941-468-1246
Old 07-03-2018, 02:10 AM
  #161
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Jim at Winamac
