Reload this Page >
New JetJoe J-Junior 4lbs turbine
Old 08-17-2009, 12:45 PM
  #301
jason
jason's Avatar
Default RE: New JetJoe J-Junior 4lbs turbine
It's about 30mm tapering to 20mm at the outlet.
jason
Old 08-19-2009, 12:25 PM
  #302
menzapsi
Hi knobby1, nick and jason
How much oil do you have in your fuel for the junior?
On the first time my junior last 6 starts and take 0,5 liter of fuel with 5,5% oil (the same fuel I use on my JJ1200) before it break.
When I get it back from Joe, it last only 1 start and after 3 min it was out, this time I have new blend with 3% oil (joe recomendation).
So I have just send it back to Joe.
Regards
jean
ID:	1259179   Click image for larger version
Old 08-19-2009, 12:56 PM
  #303
jason
jason's Avatar
I'm using 5% oil. Due to the lack of any instructions I'm not sure what JJ recommends.
Jason
Old 08-19-2009, 03:54 PM
  #304
knobby1
ORIGINAL: menzapsi
Regards
jean
Hi Jean,
Initially Jet-Joe recommended the normal 5%, however, during my testing I found this to cause a little too much carbon build-up within the combustion chamber, fuel ring and around the rear bearing support, I have since reduced this to 2.5-3% with much better results. I have since passed this onto Joe and hopefully this information will be going out to customers.
My "test/development engine" has 171 cycles and just over 700 minutes showing on the total timer, this can be a little misleading though as the timer starts as soon as the ECU is switched on, I'd suggest the engine has possibly 75% of this as actual running time....still a goodly amount of time though, the bearings are the originals and will probably need replacing very soon.
Jean, does your engine "buzz" at all during running? If so I would tend to think the balance is not good enough and may be the primary cause of the failures you are having...as with all turbines, correct balance is vital to these little engines and is quite difficult to do due to the small size of the rotative. Readings in excess of 5mg-in will cause problems.
Those of you with Juniors, please make sure the tiny brass bearing lube line which exits near the front bearing behind the compressor wheel is clear, I've had one case of a blocked lube line, the ID of this line is only ~0.005" and can block very easily... needless to say the result is not good.
A quick check is to remove the front engine cover, detach the lube line (with restrictor) from the inlet "T" fitting and lightly blow through the line, if there is flow, the line is ok.....if not, firstly check the restrictor in the line to make sure it's clear, if it is then more than likely the brass tube is blocked, normally a quick blast with some low pressure compressed air will clear it, give it a quick blast from both ends if possible!!
Attached are a couple of photos of the offending tube.
Cheers,
Smithy.
ID:	1259322   Click image for larger version
Old 08-19-2009, 04:12 PM
  #305
knobby1
ORIGINAL: tonyjms2005
Hi
Can anyone tell me internal diameter of the exhaust cone on this engine, on the mounting flange end? I may need just the jet pipe for a project.
Kind regards
Antony
Hi Anthony,
The internal diameter of the exhaust pipe at the mount flange is 35.10mm, the exit diameter for a "stock" pipe is 21.75mm. I suggest opening the exit to an internal diameter of 24.50mm which means removing ~2mm from the total length of the pipe.
Total length of the stock pipe is 27.70mm.
Hope this helps you with your project.
Cheers,
Smithy.
Old 08-19-2009, 05:23 PM
  #306
jason
jason's Avatar
Smithy
No wonder I have a hot engine, my outlet measured 21.6mm and I increased it to 22.5mm.
jason
Old 08-19-2009, 05:35 PM
  #307
menzapsi
Hi knobby1
The turbine was a little sticky from new to the first time it break. I start the turbine and every thing seems normal, I go to max RPM still OK, I came back to Idle, when I want max RPM again, at 140.000rpm I have the message SPEED LOW and the noise from the crashing compressor.
From what I have read, the best balance have to be done without disassembling the turbine.
I supose Joe balance the turbine before he send it.
Please can you tell me if I can do it with the JJ balancer and and how to proceed
Regards
Jean
Old 08-19-2009, 05:42 PM
  #308
knobby1
ORIGINAL: jason
Smithy
jason
Hi Jason,
My guess is that the pipes delivered with every engine are not all exactly the same, I've found an exit diameter of 24.50-25.00mm gives a good result without reducing the thrust by a huge amount.
Cheers,
Smithy.
Old 08-19-2009, 06:44 PM
  #309
knobby1
ORIGINAL: menzapsi
Hi knobby1
Regards
Jean
Hi Jean,
Definitely sounds like an out of balance compressor condition. The Jet-Joe balancer machine is not accurate enough to balance to the limits required, it will only get you somewhere in the ballpark and is only good to ~50mg sensitivity. A "core" balance is the most accurate method and is similar to how a turbocharger is balanced, as an assembly.
Cheers,
Smithy.
Old 08-19-2009, 07:31 PM
  #310
Xairflyer
Xairflyer's Avatar
ORIGINAL: knobby1
Cheers,
Smithy.
Hi Smithy
How did you get the pictures showing as thumbnails, every time recently I post to RCU they are full size in the post, wondering if some of my settings are wrong.
Posted a picture of my fuel needles (JJ1400) now all working as a test
Old 08-19-2009, 07:33 PM
  #311
Xairflyer
Xairflyer's Avatar
Just made a liar out of myself the picture above is a thumbnail !!
must be a setting problem on other threads as I have tried to post to the jetjoe thread and they are always fullsize ?
Old 08-19-2009, 08:42 PM
  #312
knobby1
ORIGINAL: Xairflyer
Hey Xair,
I dunno mate, I just post the pics and up they pop as thumbnails, all done with smoke and mirrors if you ask me ;-))
Good to see your fuel needles are all doing the same thing, a rarity for some of the JJ fuel rings. As you mentioned over on RCGroups, giving the main ring a little squeeze with smooth pliers at 90 degrees to each needle will often help. I, like you, believe they push the needles in too far when brazing and they bottom out inside, I see it all too often.
Cheers,
Smithy.
Old 08-22-2009, 04:18 AM
  #313
tonyjms2005
Hi
Excellent! Thank you for your swift reply.
Antony
http://tributetothem.com
Old 08-26-2009, 06:56 AM
  #314
tonyjms2005
Hi
I have watching this thread and it seems to me that there are two majorproblems with this little turbine, but when they are addressed it should be a good little engine:
The pre-load is wrong, the bearings are either too tight, giving higher egt's, or in some too loose causing movement and therefore fretting damage to the bearings.
Pre load spring poor quality, the spring is obviously of poor quality causing the preload to fail and as a result the bearings to fail, get a tidy washer for this and the it should be much better.
http://www.swcbearing.com/technical/Preload01.asp
I hope this helps.
Antony
Old 08-26-2009, 07:41 AM
  #315
jamiechip
brett the warranty agent for ausjets has already adressed these problems and solved the issue's if you buy an engine from ausjets you wont go wrong for the best set up out there
Old 08-26-2009, 12:52 PM
  #316
littlepiston
My Feedback: (12)
post a web site were one can look up aus jets?[&:]
Old 08-26-2009, 02:11 PM
  #317
ThomasP
http://www.ausjets.com/
Alistair
Old 08-30-2009, 05:31 PM
  #318
shorty55
How the engine Jason?
Any updates?
Nick.
Old 08-31-2009, 12:59 PM
  #319
tonyjms2005
Hi
Can anyone recommend a supplier for an air blower/starter for a JJ Junior sized engine?
Kind regards
Antony
Old 08-31-2009, 02:20 PM
  #320
dw_crash
There is a fellow on E-Bay that sells 12 Vdc compressors for industrial use. They have a few gallon tank on them. I tried to buy one but shipping to Canada was more than the compressor. So, I went to the hardware store and bought, on sale, a regular 120 Vac compressor and a 12 Vdc small compressor. Then, put the 12 Vdc compressor on the tank from the 120 Vac compressor. I used it for awhile to start my JJ1400 till I converted to autostart.
Just an Idea or two,
DW_Crash
Old 08-31-2009, 02:39 PM
  #321
jason
jason's Avatar
Antony
camping shops sell them for blowing airbeds up or heres one on Amazon. [link=http://images.google.co.uk/imgres?imgurl=http://ecx.images-amazon.com/images/I/4147ZdG6XXL._SL500_AA280_.jpg&imgrefurl=http://www.amazon.co.uk/240V-HIGH-INFLATOR-AIRBED-MATTRESS/dp/B0013HDHB8&usg=__EaSQF5Wni8Lg2YhylLfDsjlprag=&h=280&w=280&sz=15&hl=en&start=19&um=1&tbnid=bFW9zij4REq8KM:&tbnh=114&tbnw=114&prev=/images%3Fq%3Dpyramid%2Bproducts%2Bair%2Bpump%26nds p%3D18%26hl%3Den%26sa%3DN%26start%3D18%26um%3D1]This will last longer than your JJJ :-)[/link]
Jason
Old 08-31-2009, 02:51 PM
  #322
tonyjms2005
Hi
Thanks, Its ok I haven't got a JJ, It for one of myown built ones.
cheers
Antony
Old 08-31-2009, 02:56 PM
  #323
jason
jason's Avatar
Antony
you have more of a chance then
Jason
Old 09-01-2009, 06:53 AM
  #324
tonyjms2005
Its a shame JJ dont do all their engines as a kit because then, as you build the engine you can iron out all the flaws, like the semi working fuel rings and bad soldering (maybe with one or two engines, but this is just an example), maybe even do one ortwo mods if you know what your are doing to prolong engine life.
That way you could have a decent engine that will last well.
Cheers
Antony
Old 09-01-2009, 10:27 AM
  #325
Xairflyer
Xairflyer's Avatar
Its a shame JJ dont do all their engines as a kit because then, as you build the engine you can iron out all the flaws, like the semi working fuel rings and bad soldering (maybe with one or two engines, but this is just an example), maybe even do one or two mods if you know what your are doing to prolong engine life.
Cheers
Antony
Solution is to strip it when you buy, make it a kit [sm=idea.gif] we might have a JJJ stripdown thread added soon so you will have no excuses
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
