Reload this Page >
New JetJoe J-Junior 4lbs turbine
Old 11-04-2009, 06:29 AM
  #501
Xairflyer
Xairflyer's Avatar
Default RE: New JetJoe J-Junior 4lbs turbine
Is that SMC that do the pneumatic fittings (festos as we call them) ?
Old 11-04-2009, 11:51 AM
  #502
menzapsi
Hi Xairflyer
Here you have pictures of the fluid control of my JJ1200 with
- the S070B for gas
- the V114A for fuel
- and the MTH pump
this is a single package to hold in place with 2 screws
On this site you can download a PDF for SMC valves
http://www.smc.eu/portal/NEW_EBP/Lev...lenoid%20Valve
Hi chichisport
For spanish you can go to
http://www.smc.eu/portal/NEW_EBP/Lev...s%203%20v%EDas
Jean
ID:	1307797   Click image for larger version
Old 11-04-2009, 02:55 PM
  #503
chichisport
Nice pack . I always liked modular designs!!!
Old 11-04-2009, 07:50 PM
  #504
seravios
wow...very neat.....
Old 11-05-2009, 01:45 AM
  #505
Fabian_Swiss
Hello and good morning,
yesterday I tried again to start ther turbine.
I assembled the glow plug and when I switched on the FADEC there was the message again: COOLING and the temperature was nearly 300°C.
I dissassembled the glow plug and the ambient temperature was displayed.
There is a short circuit between the negativ glow plug wire and the temperature sensor.
It is not the original one, it is a custom made one.
So do you have any suggestions how to solve this problem?
To isolate the sensor is impossible - the only solution is to make the hole in exhaust a little bigger and then hope therewon`t be ashort circuit again
but this is not a acceptable solution....
I am going crazy with this turbine....
Greetings Fabian
Old 11-05-2009, 04:27 AM
  #506
i3dm
My Feedback: (51)
Fabian,
Sounds like you have a faulty ground int he temp sensor, shorted to the sensor case it self. replace the temp sensor is thats the case.
Old 11-05-2009, 04:43 AM
  #507
Fabian_Swiss
Hello,
I have just talked to the electronic experts here in the factory and theytold methe same.
Now I have a new sensor and will try again this evening....
Hope it will work.
And maybe one day the turbine is running :-)
Greetings and thank you!
Fabian
Old 11-05-2009, 06:54 AM
  #508
jason
jason's Avatar
Fabien
I wouldn't bother with the automatic glow anyway. Try in manual mode so dont plug the glow plug lead into the ECU and when the display show 'Ready' just put a normal glow clip on and light the gas once it reaches 100 deg it will show 'Fuel Ramp' and away you go. Hold the blower on until 70k
Jason
Old 11-05-2009, 07:11 AM
  #509
seravios
Jason,
In my case, I noticed when the rpm reaches between 30k to 50k , the rpm progresses very slow,sometimes halt for a while then slowly increase again. What parameter can I adjust?
seravios
Old 11-05-2009, 07:12 AM
  #510
Fabian_Swiss
Hi Jason,
thats a good idea!
I will try it and maybe it works....hope so.
Thank you a lot for this suggstion.
Greetings Fabian
Old 11-05-2009, 07:56 AM
  #511
jason
jason's Avatar
ORIGINAL: seravios
Jason,
seravios
I don't have an ECU here and I can't remember what the parameter is termed as but it something like "Fuel ramp" or Start ramp" I'd put it up two and try again.
It's not the pump start voltage which is termed as "Auto + #"
Jason
Old 11-05-2009, 02:41 PM
  #512
knobby1
ORIGINAL: seravios
Jason,
seravios
Hi Seravios,
To increase the "ramp to idle" speed, you can adjust a few things, firstly the "pump ramp", a nice quick start can be achieved by increasing this parameter to 006, in some cases 008 is usefull. Also in the sub-menu, (parameters 028, 029 and 030), set 028 to 003, set 029 to 001 and set 030 to 003, this can help greatly with the ramping sequence up to idle. Of course a lot depends on how good the fuel pump is at very low voltages. The new J-200 fuel pumps are actually quite good which is a nice surprise. Adjust the pre-heat parameter to 4 secs.
As Jason has correctly mentioned, keep the blower on until the rpm's reach at least 70k, the engine will only self sustain above ~64-65k.
It's better to have a relatively quick warm start and ramp to idle, rather than a long hot one.
If you would like a full set of Junior parameters, let me know and I'll organise to send you a set.
All the best,
Smithy.
Old 11-05-2009, 08:05 PM
  #513
seravios
thank you Smithy. Pls send me the parameter that u mentioned, greatly appreciated. < [email protected]>
Old 11-10-2009, 02:58 PM
  #514
Andy Sheldon
A few Pictures taken at Long Marston on Monday by Jason. Excellent Camara work Mr Fletcher
Checked ECU and last flight of the day was the 50th.
Andy
ID:	1311651   Click image for larger version
ID:	1311652   Click image for larger version
Old 11-10-2009, 08:38 PM
  #515
seravios
Vortex32 maiden flight.
http://www.youtube.com/watch?v=Op22DUNmBYA
Old 11-11-2009, 02:34 AM
  #516
Grumman
Good One Guys!!! Thanks for sharing the video... Nice looking Bird... Just wondering what was your total weight?
Thanks & Happy flying!!!
Mojo
Old 11-11-2009, 02:44 AM
  #517
seravios
ORIGINAL: Grumman
Mojo
AUW : 2700gm ( with 475ml main tank and 125ml header tank)
Old 11-11-2009, 05:22 AM
  #518
jason
jason's Avatar
ORIGINAL: seravios
Seravios
could you post some pictures of the install please? I have a Vortex here and and about to start the install so could do with a few ideas.
thanks
Jason
Old 01-08-2010, 02:17 PM
  #519
tonyjms2005
Hi
I have nearly finished my own desgin of micro turbine, It uses a 40mm compressor and a2 stage diffuser.
I will start to test the engine in the next couple of weeks, fingers crossed.
Antony
ID:	1352009   Click image for larger version
ID:	1352010   Click image for larger version
Old 01-08-2010, 02:27 PM
  #520
rjbob
My Feedback: (8)
rjbob's Avatar
ORIGINAL: tonyjms2005
Hi
I have nearly finished my own desgin of micro turbine, It uses a 40mm compressor and a 2 stage diffuser.
Antony
My fingers are crossed, too...GOOD LUCK!
Old 01-08-2010, 02:57 PM
  #521
jason
jason's Avatar
Hi
Antony
what turbine wheel are you using? Any pics of the hot end?
J
Old 01-09-2010, 12:01 PM
  #522
tonyjms2005
Hi
The rotor assembley is off a small car turbo rated to 211,000 rpm so I know that it is balanced to a high standard and will take the speed of the shaft.
Cheers
Antony
Old 01-09-2010, 03:06 PM
  #523
tonyjms2005
Here is a photo of the tunnel/rotor/diffuser assy, this was a single stage diffuser I made from hand, just as a quick experiment,but I really wanted it to have a 2 stage diffuser, so I had one machined.
Correct me if I am wrong but the j-junior only uses a 1 stage diffuser?
Antony
Old 01-31-2010, 09:05 AM
  #524
seravios
The vortex32 with Lambert turbine.
ID:	1368588   Click image for larger version
ID:	1368589   Click image for larger version
ID:	1368590   Click image for larger version
ID:	1368591   Click image for larger version
Old 01-31-2010, 09:45 AM
  #525
jason
jason's Avatar
ORIGINAL: seravios
Are you going to fit a cover over the engine? I know the supplied plastic one won't do but I considered making one out of mesh and painting it white.
Jason
