Turbine manufacture will follow jetcat??
RE: Turbine manufacture will follow jetcat??
ORIGINAL: mdeseve
will they follow jetcat for the price reduction?
Wren prices have always been competitive, and the fall in the value of the British pound over the last few months has meant price reductions on our engines. Several other manufacturers (both within and outside Europe) already had lower prices than JetCat anyway, so perhaps they are just keeping up with the market.
It's good news for the customers!
Sara Parish
Wren Turbines
My Feedback: (14)
ORIGINAL: zonker123
I just ordered a Artes Falcon, so prices will drop the day after I get it.
And you also got an excellent service, support and the only brand engine with a real Life Time Warranty. All this with a true thrust output.
ORIGINAL: mdeseve
If you compare thrust for thrust, the p-80se is $500 cheaper than the supersport and have 2 pound more of thurst.[8D]
My Feedback: (10)
ORIGINAL: Couch Potato
Yeah, but the P-80 is the size of a house, weighs a ton and might take a whole flying season to get serviced/repaired. [:-]
ORIGINAL: mdeseve
My Feedback: (10)
FL
Doesn't sound like AMT USA / US Microjet will be around much longer.
The boys from AMT Netherlands are doing a great job!!!! Honest, easy to deal with, they do what they say and have a great product with many happy customers.
Description
evoJet BOOSTER 90 - the Beast - small, light and impressive. The ultimative power stuff for all fuel savers without loosing the jet flying-pleasure. List of small to medium-sized jets (single jet up to 14 kg = 31 lb):
CARF-Flash, Rookie, Mig-15 or BOOM-ERANG-Sprint, Elan or TOMAHAWK; ViperJet or PAF; JetCo, T-33, U-2A, Sting a.m.m.
The extraordinary jet is the BOOSTER 90 (twin installation - up to 25 kg = 55 lb), in big jets like MIBO; A-10 or Skymaster; F-4 Phantom or JL; F-18 Hornet.
The evoJet Booster series of model turbines works in a similar fashion to full-size jet aircraft power plants. The engines features an electric starter motor and a new electric kerosene burner (SFL12V), providing full controlling the engine startup from the R/C transmitter. There is no more dangerous propane gas needed. NEW, is a Single Fuel Line and a rock-solid 12V kero-burner system. No more second start-fuelline needed !
All processes are supervised and monitored by the JETRONIC-Vx Engine Control Unit, which constantly sets all the operating parameters to the optimum values. All the auxiliary electrical components, i.e. fuel pump, kerosene igniter, starter, valve etc., are powered by a lightweight lithium-manganese battery.
The latest precision CNC and laser technology is employed to obtain an unprecedented level of manufacturing precision, guaranteeing that the turbines provide high performance and a long effective life.
Each set also includes a display and pro-gramming unit (Engine Data Terminal) featuring an illuminated alpha-numeric LCD; it can be plugged in and disconnected when the engine is running, so that you can read off the current operational data and adjust the settings if necessary.
In addition to the momentary operational data such as exhaust gas temperature (EGT), rotational speed (rpm) and thrust (Throttle), the unit is also able to display statistical data including total turbine running time, rotational speed and temperature statistics, number of starts, battery voltage etc.
SFL12V - ceramic kerosene-burner for fully automatic engine startup with no propane gas and no separate start-tubing.
Combustion chamber and turbinestage made of Inconel high-grade steel - to ensure fastest throttle control and longest operation.
Aerospace-aluminium parts for lightest design combined with highest tightness.
Engine sensors (mil.spec.) fully integrated and therefore best protected.
Precision balanced rotor for best running performance spares the ceramic-hybrid bearings (abec9).
Ball beared startermotor with neodym-magnets for quick engine startup.
Mini-JETRONIC-Vx ECU - extra lightweight and with powerful firmware - reliable and over 5 years 'ripened'.
Technical specification: Thrust: typ.9 kg=20lb @165,000
Weight bare: 950 g = 2.1 lb
Diameter: 91 mm = 3.6 inches
Rev speed: 48,000 - 165,000 rpm
Exhaust gas temperature: 650°C - 750° C
Fuel: 250g=8.8oz/min Jet A1
Lubrication: 5% turbine oil in fuel
Maintenance
interval: 50 hours
1985,00 EUR / 2102,11 US$ without German Taxes
My Feedback: (21)
ORIGINAL: avicom
ORIGINAL: zonker123
Its just my luck there will be a price reduction next week after it gets to the house.
It won't make me regret my purchase, just the timing!!
And what about the Merlin 90 ?
Certified minimum full thrust: 95N (21lb) at 152.000 RPM
Diameter: 90mm (3.5â€)
Engine weight: 1010g (2.2lb) (including mounting strap)
Airborne weight: 1,200g
Fuel: Kerosene + 3% - 5% oil (synthetic 2T motorcycle oil or turbine oil).
Pressure ratio: 3.1 to 1
EGT max: 620ºC
Massflow: 180g/sec
Fuel comsumption: 350ml/min at 95N (11,5oz/min at 21lb)
200ml/min at 60N (6,6oz/min at 13,1lb)
Price: Gas Start version 1.800€ excluding VAT
All the engines I have tried ( 5 so far ) have given me a nominal thrust of 100 N with peak EGTs as cold as 570 °c.
The version I am running right now on the Phoenix is capable of 110N. Gaspar is working on a new compressor design that will improve the reliability at these level of thrust.
I believe that this one is setting the industry standard right now. Not the Booster anymore...
EGT max: 620ºC
Massflow: 180g/sec
ORIGINAL: olnico
EGT max: 620ºC
Massflow: 180g/sec
EGT max: 620ºC
Massflow: 180g/sec
And what about the JC Rabbit. Basically identical to the merlin 90 except it looks better!!!!!!!!
Mav[8D]
My Feedback: (10)
FL
Zonker123:
Thank you for selecting Jet Central's Falcon. Twenty two pounds of thrust, Lifteime Warranty as well as a complete turn key package. Welcome to the fastest growing turbine family in existance today!
Our phenominal sales at FJ 09 tell us that we have it right. . .right price, right value, right package, right thrust options and without question, the right team. We were in full force withour support team assisting with everything from installs to minor adjustments.
Please note: If we for any reason reduce prices in the next quarter, you will be refunded the difference or offered product credit in exchange. At this time, there are no plans to increase or decrease our prices.
Best regards,
Eric Clapp
Best regards,
Eric Clapp
My Feedback: (57)
ORIGINAL: mdeseve
Hi Eric, you know what , i'm getting ready to buy a jc rabbit, the size and thrust is exactly what i need, and if the price change and you give a credit , that is a great service.
They nailed it with that little sucker.
What we need now is a Jet Central Falcon sized turbine that can put out 30 lbs of thrust. I'm sure you guys must have plans of using the same technology on larger engines, right?
ORIGINAL: FalconWings
You will not be dissapointed. I love mine more and more every weekend.
ORIGINAL: mdeseve
I'm in the market for an 18-20lb turbine and when you take out those that are sold through a retail premises, those that are serviced in the UK, your pretty much left only with one choice, which of course is the most expensive one
