Boomerang XL Nose - Removable??
I have seen a couple posts about "ideas" of how to make the new nose removable but has anyone done it? Maybe this is one of those "leave well enough alone" and use some CA. I had thought about extending a plywood horizontal base out from the bulkhead, put a small block with blind nut on the end. On the nose....put a half inch of epoxy in the end around a piece of metal tubing to be used as a guide for a bolt through the nose to connect with the blind nut. The more I think about it, the better I like CA[&:] Not cool to fly around with a nose that looks like it belongs on the Concorde.
