Reload this Page >
Jets with the Futaba 14MZ And 2.4 6014FS
Old 05-18-2009, 03:35 PM
Mitchell-RCU
My Feedback: (49)
Default Jets with the Futaba 14MZ And 2.4 6014FS
Is it safe to fly my new Kingcat with a Futaba 14MZ with the 6014FS 2.4 receiver? What i have been reading makes me wonder.
I have two Duralite 2700Mah Li-ion packs that are independantly switched and regulated to 5.1 V, 9 JR 8611SA servos on all control surfaces, and Futaba 3101 servos on the brakes and retracts.
Mitchell
Old 05-18-2009, 04:03 PM
quist
My Feedback: (198)
quist's Avatar
Default RE: Jets with the Futaba 14MZ And 2.4 6014FS
We have been using that same setup in our jets and IMAC planes since it came on the market.  I flew all last summer in the AZ heat without one problem.  I have setup a Kingcat, Ultralightning, Flash, and 3 Boomerangs, with the 6014rx and I have never had a bad or questionable range check.
Old 05-18-2009, 04:04 PM
JetsRC
JetsRC's Avatar
I have used this mix in a F-4, F-18F, Rafale, F-16 and many others with never a single glitch.
Old 05-18-2009, 04:27 PM
RCI/Skymaster
Banned
I'v been using the system for a few months now. 1/6 Skymaster F-16 and a Skymaster Viperjet.
No problems at all.
Old 05-18-2009, 04:42 PM
schroedm
schroedm's Avatar
All I've used for 18months. Never a problem.
Old 05-18-2009, 06:43 PM
samo
Been using it in two jets for a year and a half now and not a single problem it is rock solid. We have a 6014 in a Flite Metal F-84G with zero problems as well.
Drew
Old 05-18-2009, 07:10 PM
FILE IFR
FILE IFR 's Avatar
As with any installation, keep the RX away from other electronics (pump, ECU) and need not worry.
Spread the antennas per the manual too. I have the same equipmentandhaveno problems... none.
Old 05-18-2009, 07:12 PM
Mitchell-RCU
My Feedback: (49)
Thanks for the help. I have been reading about problems with these receivers and i wanted to get some feedback from people actually using them. It range checks just fine so i think i'll take it to mid atlantic jet this weekend.
Mitchell
Old 05-18-2009, 07:22 PM
FILE IFR
FILE IFR 's Avatar
For me, part of my succsess isnot toroll my planes onto the ramp and let it sit and bake in the hot sun for hours; regardless of the radio brand, that is just careless.... plain and simple.
Old 05-19-2009, 04:06 AM
GrayUK
GrayUK's Avatar
6014 with 12 FG.
18 months (plus) in Jets, heli's, Props.
Zero problems, not a single glitch, twitch or otherwise.
Make sure you keep the aerials at or around 90 degrees to each other.<o></o>
Paul<o></o>
Old 05-19-2009, 04:19 AM
extra 300
I am very interested as i need to go either 12 FG or all the way to 14 MZ.
Any info on RXlockout due to overheating (i.e. extensive servo operation) resulting in necessary use of power Expander/Powerbox to separate RF from servos??
Your feedback in this respect would be much appreciated.
Best regards,
Old 05-19-2009, 07:46 AM
GrayUK
GrayUK's Avatar
ORIGINAL: extra 300
Best regards,
No problems with any of the above. (Never had a rx lockout).
Try this thread.
www.rcuniverse.com/forum/m_6188151/tm.htm
Paul
Old 05-19-2009, 08:18 AM
tahfiet
tahfiet's Avatar
Hi guys!
No problems for me and my dad the last 12 months with T-14MZ and 2G4. We have flown it in the following airplanes:
Facet 1200
Graupner Harpoon II
BTE Reaction R54
PAF Sting
Tomahawk Viperjet
Airworld Cougar
Rödelmodellbau Tutor
Grumania P-59 Airacomet
Airworld Cmelak with 250 radial
Just to name a few
David
Old 05-19-2009, 08:49 AM
figueroa
My Feedback: (22)
figueroa's Avatar
I switched my 14 MZ to 2.4 and have had no problems with 6014 FS receiver ( gold dot)in my Boomerang XL. Just got one of the new 6014 HS receivers which I installed in my new L 39. I will eventually switch all my planes to 2.4.
jef
Old 05-19-2009, 09:27 AM
quist
My Feedback: (198)
quist's Avatar
Wow, this thread is 24 hours old and still 100% positive.  Nice.
Old 05-19-2009, 09:51 AM
747drvr
747drvr's Avatar
OK , I'll keep it going then ! Twenty FASST RX's in service .  Six turbine powered aircraft . Zero problems
Old 05-19-2009, 10:33 AM
George
My Feedback: (57)
12Z and (2) 6014FS's - ZEROPROBLEMS!
Old 05-19-2009, 12:05 PM
Ron101
My Feedback: (22)
Ron101's Avatar
I have a 12 FG...
and have Fasst everything I own... Ifly only really high power electrics some 4000 + watts and 100 amps +
This is a very noisey and hot place for a RX to be...
I have never had a single problem... not a glitch ... just rock soild and trouble free
love it
Ron
Old 05-19-2009, 12:07 PM
Bob_B
Bob_B's Avatar
I'm flying a 12FG since last October so I have the older 6014FS Rx. This is installed in an Electra Jet.
High power edf's are one of the worst environments for a radio to operate in.
ZERO Issues with this system!
Bob
Old 05-19-2009, 02:33 PM
Shui
Shui's Avatar
I've been flying the 14MZwith the 6014 for 2 years now in many jets - 1 issue.
I had 1 range issue on a chrome giant F-86 that was fixed once I relocated the receiver. I think this was a special case due to the size and amount of equipment in the plane, along with the chrome finish.
Other than that its a solid link and simple to install and bind. I've run it on a single battery/regulator, powerbox's, smartfly's, etc.
Old 05-19-2009, 02:44 PM
AirTramp
AirTramp's Avatar
12FG transmitter with 6014 receiver bought in January 2008. Installed into a 35% AeroWorks Extra 260. Running eight JR DS8611and one Futaba 9202. All connected to the receiver. I did modify the power buss in the receiver to handle 20 amps. No power box, no power expander and no match boxes. I did all the servo matching in the transmitter. No glitches, no lock-outs and no problems.
Old 05-19-2009, 02:56 PM
George
My Feedback: (57)
What kind of mod and do you have pics?
Old 05-19-2009, 03:10 PM
BaldEagel
BaldEagel's Avatar
I have a FG with a 6014HS with a red dot and it preforms perfectly, no glitches or any lock outs on Jets or Electric 3000 watts.
Mike
Old 05-19-2009, 03:19 PM
GrayUK
GrayUK's Avatar
This is turning into a good thread.
Great stuff.
Paul
Old 05-19-2009, 03:38 PM
Nick Yuhasz
Nick Yuhasz's Avatar
Using the 14MZ for 5 years andwith 2.4Ghz6014s for 2 years with no problem in my jets. Since using the 6014's, I do use SmartFly(PowerExpander14MZs & now PowerExpander Competition 12s) with 2 A123 packs forthe receiver. I don't use Futaba servos; I use JR or Hitec digitals so I want to be safe regarding the signal voltage from the 6014's.
Nick
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
