 12X Retract program problem >
Old 06-15-2009 | 04:34 PM
Default 12X Retract program problem
I have an AR9000 Rx on a Smartfly EQ10. My problem is the gear servo cyclesto gear up momentarily till it bindsas soon as the Rx is powered up. The radio is bound, the throttle failsafes properly. I am using a Behotec gear and brake combo valve and it is programmed to apply brakes with down elevator. Eric
Old 06-15-2009 | 04:39 PM
k12rc's Avatar
Default RE: 12X Retract program problem
rebind with gear down
Old 06-15-2009 | 04:44 PM
I have rebound with the gear down many times and it does not change. Eric
Old 06-15-2009 | 05:17 PM
Countryboy's Avatar
My Feedback: (25)
My guess is that you have an analog servo plugged in on the gear channel. Try plugging in a digital servo and see if the problem goes away.
Old 06-15-2009 | 05:33 PM
Countryboy You were absolutely correct. This is my first 2.4 radio and have to learn a few new twists. Thanks Eric
Old 06-15-2009 | 06:01 PM
Countryboy's Avatar
My Feedback: (25)
Well, I only learned that there was a problem with 2.4 and analog servos after I booted and promptly flopped the plane on the ground knowing full well the gear switch was in the gear down position.
Here is the thread by whch I learned of the issue.
http://www.rcuniverse.com/forum/m_78...tm.htm#7878550
