Reload this Page >
Jet Cat Help Please
Jet Cat Help Please
Old 06-15-2009, 07:50 PM
TED ANTON
My Feedback: (7)
TED ANTON's Avatar
Default Jet Cat Help Please
Hey guys
I have a problem with my P120
Engine ignites ,fuel pump startsengine ramps upfor a few seconds then shuts down
GSU reads" ACC SLOW" pump voltage and settings are good,battery fine, fuel pump test is fine
Any suggestions
Ted
Old 06-15-2009, 08:33 PM
acw
Default RE: Jet Cat Help Please
A couple of ideas, assuming this is a gas start. I don't know anything about kerostart.
- clean the fuel filter.
- Increase the initial pump voltage
Arnaud
Old 06-15-2009, 08:47 PM
trioval00
My Feedback: (17)
I went through the same problems a few years ago, here the fuel pump went bad on me.... but it might be as simple as cleaning the filter.
I was once told to run the pump in the opposite direction, this will help clean out and garbage that might be in the pump... and I was also told by someone else to pull the pump apart and look at the pump gears, might be debris in there that will not let the fuel pass through. I diod all that, but it was the pump itself that was bad....
Mark
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
