Reload this Page >
CARF CT-114 Tutor 2.6m Build thread
Old 03-05-2010, 02:31 AM
  #51
Dave Wilshere
Default RE: CARF CT-114 Tutor 2.6m Build thread
Paul
Yes, in Europe (tax paid) 2190 Euro. Undercarriage is additional, as is Fuel tank (Hawk tank) and Smoke tank (Flash wing tank)
Lot of aeroplane for the money!
Dave
Old 03-05-2010, 07:55 AM
  #52
E.N.T.
Hi! Dave; I already ordered mine to Andy Kane with a different paint scheme.
So I'll be waiting for mine.
ENT
Old 03-05-2010, 09:01 AM
  #53
Dave Wilshere
ENT
Cool, del in Europe on stock scheme is still around 6-7 weeks for the first ones
regards
Dave
Old 03-14-2010, 04:48 PM
  #54
Dave Wilshere
Cleared my other projects from the workshop and started the Tutor today. Really looks like a quick build with lots of little jobs done. Looking at surfaces first, wing uses stock CARF servo mounts on the ailerons (pix) and new mount design on the flaps which has a factory installed mounting plate that the flap servo mount screws to.
Dw
ID:	1398162   Click image for larger version
ID:	1398163   Click image for larger version
ID:	1398164   Click image for larger version
ID:	1398165   Click image for larger version
Old 03-14-2010, 06:08 PM
  #55
Dave Wilshere
Really is going to build quickly, flaps hooked up to check rod lengths etc.
ID:	1398238   Click image for larger version
Old 03-14-2010, 06:26 PM
  #56
i3dm
My Feedback: (51)
Dave,
RE TM decals, how are you planning to adhere them to the painted in the mold airframe ? will you clear coat after applying them ? did you scuff up the surfaces first ? please share some info.
Old 03-14-2010, 06:52 PM
  #57
Dave Wilshere
These decals don't need clear coat, they are printed on the adhesive side of clear sheet. You just clean the aeroplane with spirit and apply!
regards
Dave
Old 03-15-2010, 11:21 AM
  #58
i3dm
My Feedback: (51)
Dave,
are they water transfer or adhesive back tupe ?
Old 03-15-2010, 02:44 PM
  #59
snobird
My Feedback: (36)
snobird's Avatar
they stick on, adhesive, they are very high quality
Old 03-15-2010, 03:33 PM
  #60
Dave Wilshere
Aileron servo mount and direct pushrod. Flap linkage is internal and very positive. I love an aeroplane with big flaps...this is going to be hit the side of a house braking
Dw
ID:	1398874   Click image for larger version
Old 03-17-2010, 02:58 PM
  #61
Dave Wilshere
A little more looked at. Playing around with gear door rams, also note carbon on main gear mount, two carbon ribs and laminated plate
Dw
ID:	1400115   Click image for larger version
Old 03-17-2010, 04:36 PM
  #62
Dave Wilshere
Positive nose linkage...
Old 03-20-2010, 04:55 PM
  #63
Dave Wilshere
Little bit more done today, working on one wing to get everything finalised, I have the gear in and leg gear doors hinged.
Dw
ID:	1401699   Click image for larger version
Old 03-21-2010, 06:17 AM
  #64
AIRMAR72
nice jet dave! carf model rules RC aviation five star rated models across the board website always working and updated customer service and sales rep easy to work with
Old 03-21-2010, 01:12 PM
  #65
Dave Wilshere
Having fully sorted one wing I'm completing the other one! Note the tabbed gear mount-carbon and plywood. Also the lightened spar which gives access for the flap and aileron leads to the D box. Also interesting wing section at the root
Dw
ID:	1402180   Click image for larger version
ID:	1402181   Click image for larger version
ID:	1402182   Click image for larger version
Old 03-23-2010, 09:56 AM
  #66
E.N.T.
Hi! Dave, my wife's fathers day gift was ordered to Andy,
( and paid) also. gold/red scheme. Will post photos when it arrives. So
keep those photos coming.
Hector
Old 03-23-2010, 11:49 AM
  #67
Dave Wilshere
Hector
Great, lucky man...
Will start the fuselage tomorrow
regards
Dave
Old 03-23-2010, 12:18 PM
  #68
E.N.T.
Are you using the stock retracts? And which turbine.
Is there any posibility of using Robarts?
Hector
Old 03-23-2010, 12:28 PM
  #69
simonmiller
Dave,
Counting the days, hours & minutes before I am back in the game!
What other paint jobs is this puppy going to come in?
Simon
Old 03-23-2010, 02:00 PM
  #70
Dave Wilshere
Hector
Yes, stock Behotec gear with Intairco main wheels. I wouldn't change it, 3 1/2 years in my Flash and no problems, lots of grass abuse...great gear. The retract angles are not 90 degrees, the CARF gear set is designed for the Tutor and I'd go that way.
P160SX turbine, with the 4.2ltr tank and my flying style that's 10-11 minutes.
Simon...me too
Dave
Old 03-23-2010, 05:08 PM
  #71
Dave Wilshere
Pipes run, final horn position, some shots of the gear.
ID:	1403555   Click image for larger version
ID:	1403556   Click image for larger version
ID:	1403557   Click image for larger version
ID:	1403558   Click image for larger version
ID:	1403559   Click image for larger version
Old 03-29-2010, 10:25 AM
  #72
E.N.T.
Hi! Dave; hope the project continuing as expected.
More photos please.
Terry Labonte was kind enough to send me the tank and plumbing,
will be waiting to see how long it takes to finish the plane
and be in my hands.
Thanks, Terry.
ENT
Old 03-29-2010, 11:46 AM
  #73
Dave Wilshere
Terry
Yes, minor delay getting back as we had our Jet Modellers AGM this last weekend and I have another model to finish before shipping to a customer. Back on it by Wednesday
regards
Dave
Old 03-31-2010, 11:56 AM
  #74
SAP_2000
SAP_2000's Avatar
The wait has begun
I wonder if this plane originates from the [link=http://www.roedelmodell.com/html/tutor.html]Rödel Modellbau kit[/link], or if it's a completely new design?
Very simillar specs...
Old 04-08-2010, 05:36 PM
  #75
Dave Wilshere
Just back on this project,
Tank is complete check shows clunk goes 360 degrees..dry!
My wheel alignment method, the wing root is parallel
Nose unit drops into pre drilled holes...
Holes in fin former for leads
Dw
ID:	1414461   Click image for larger version
ID:	1414462   Click image for larger version
ID:	1414463   Click image for larger version
ID:	1414464   Click image for larger version
ID:	1414465   Click image for larger version
ID:	1414466   Click image for larger version
ID:	1414467   Click image for larger version
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
