Reload this Page >
how to block air line nipple?
Old 02-12-2010, 04:54 PM
overnout
Default how to block air line nipple?
Looking for suggestions on how to block some extra airline nipples on a pneumatic valve.
Thanks in advance
Old 02-12-2010, 04:59 PM
jason
jason's Avatar
Default RE: how to block air line nipple?
Warm the end of some tube with a heat gun and lightly press with pliers to seal one end.
jason
Old 02-12-2010, 05:56 PM
Greg Wright
Greg Wright's Avatar
you could use a small drop of silicone or epoxy to seal them. Then if you ever need to use them you can peel it off after.
Old 02-12-2010, 06:51 PM
flyexperimental
Epoxy for me also.I use a drop of 3M panel bonding adhesive,used to glue on qaurters,roofs ect. on cars.
Old 02-12-2010, 07:11 PM
Randy M.
My Feedback: (38)
I just jumped them together on a robart valve, closed them both.
Old 02-12-2010, 09:57 PM
SinCityJets
solder
Old 02-12-2010, 10:31 PM
noahb
My Feedback: (67)
+1 on the solder. To me if you can't jump the airline to another nipple as stated then I solder the very ends. This has proven 100% reliable so far for me. If in the future you need that nipple port, then just apply a tad bit of heat with either wix or 1 or 2 psi of air and it comes right out (wear safety goggles!).
Just be careful that you don't heat the entire valve up and mess up the orings.
I just use a pencil type solder iron.
Hope that helps.
Old 02-13-2010, 09:14 AM
ckeene9
My Feedback: (-1)
Solder an airline restrictor closed then if connect it to the valve with a very small piece of tubing. Then if you ever need that nipple you just pulling the airline off.
