Reload this Page >
balsa bandit & ramtec
Old 07-18-2003, 07:25 PM
bill zuke
Default balsa bandit & ramtec
hi,
i have a new balsa bandit on the way.
i have now an os91 and a ramtec fan. i have
been told i can use the os91 but not the ramtec fan.
supposidly i need a viojet fan and pipe etc.
being pretty much a rookie i could use some help
in this matter can i or can't I????
regards,
billzuke@hotmail.com
bill
Old 07-18-2003, 07:28 PM
grbaker
My Feedback: (29)
grbaker's Avatar
Default Probably not
All of the ducting in the Bandit is going to be sized for the BVM fan unit which is smaller in diameter than the Ramtec or Dynamax.
Old 07-18-2003, 07:59 PM
Kevin Greene
My Feedback: (85)
Kevin Greene's Avatar
The Bandit is designed for the BVM fan unit. You would have to do extensive mods to make the Ramtec work...Not worth it in my opinion. The inlets on the Bandit are small and are optimized for low drag and the Viojet fan unit. The Ramtec needs a larger intake area than the Bandit can provide. All of the interior structure is designed for the BVM fan. To do it right would require a lot of work. (And money!!!) If it were me I would sell the Ramtec and apply that money toward a BVM fan. If you were ever to try to sell the model the Ramtec, and the mods associated with it, would lower your planes value as compared to keeping it all BVM.
Kevin
Old 07-18-2003, 09:33 PM
sandslx
Kick that O.S. ramtec combo to curb!
Call Patty or Dave and get it done right the first time.
You will save yourself 500.00 bucks worth of Excedrin...... from banging your head against the wall.
Old 07-18-2003, 09:48 PM
Kevin Greene
My Feedback: (85)
If you are interested I have a friend that has a NIB BVM .91 and BVM fan unit for sale. He might have the pipe too. He is selling these to pay for the turbine conversion kit on his BVM F-16.
Kevin
Old 07-18-2003, 10:39 PM
DavidR
Do yourself a BIG favor and go with the Viofan and BVM .91 or .96 they work and the airplane is designed for them. The OS .91 will not last long in the BVM fan unit.
Old 07-18-2003, 10:56 PM
Shaun Evans
Shaun Evans's Avatar
Not to disagree with Dave or anyone else, but after hearing for years that the O.S. .91 won't last long in the BVM fan, I did it anyway. Why? I called BV and he said to go ahead! He said it wasn't going to be as good as the BVM engine in there, but that I didn't need to worry about all the rumors and suppositions. Between the A-4 and the Starfire, we got around 85 flights (I don't know if you consider that long enough to know if it's going to be problematic) without any difference between the first one and the last one.
Having done it, I'd do it again without hesitation...
Old 07-19-2003, 06:02 AM
AHMET
Default BWM 91R
Hello guys
Bwm engines are mos expensive than O.S.product and here is why....
They made of better materials.
They have a lower level of vibration.
They can achieve and stay together at higher RPM's 32.000
BEST REGARDS
AHMET
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
