Reload this Page >
3mm non-return festo-type valve?
Old 08-15-2010, 12:07 PM
smitty1001
My Feedback: (29)
smitty1001's Avatar
Default 3mm non-return festo-type valve?
Does anyone know if they make a 3mm non-return festo-type valve? and/or where to find one?
Thanks in advance!
Old 08-15-2010, 12:14 PM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Default RE: 3mm non-return festo-type valve?
i dont think there is one on 3mm......
you can use 3 to 4 then the one way 4mm valve then anothher 4 to 3
Old 08-16-2010, 10:21 PM
Gordon Mc
ORIGINAL: smitty1001
Thanks in advance!
What exactly do you mean by 'valve' ? Are you looking for a ballcock style valve, or an adjustable rate valve, or ... ? Or maybe not a valve at all and just a one-way coupler ?
Old 08-17-2010, 02:03 AM
highhorse
highhorse's Avatar
Old 08-18-2010, 04:06 PM
smitty1001
My Feedback: (29)
smitty1001's Avatar
Gordon, Iwas looking for anything to put "in-line" to isolate my two air systems before a "T-off" to fill with one disconnect. After our last thread Ihave tried a couple different ways of "skinning the cat" to air fill and the one Ilike the most is using a single Quick Disconnect with a "T" to the "insert-tube-in-bvm-valve method"
Iam now ready to eliminate the BV valves and just need a one-way pass through to keep the sys's seperate. I'm hoping to ziptie everything and it become a below-the-deck install with a single quick-disconnect pigtail to plug in to.
Ithink these will do the trick: http://www.tamjets.com/original/prod...roducts_id=114
ID:	1486209   Click image for larger version
ID:	1486210   Click image for larger version
Old 08-18-2010, 04:25 PM
Gordon Mc
In that case, for your one-way requirements as shown in your drawing you can probably use a small 3mm one-way coupler like the one that Jetcat supplies for propane-filling.
See part A-1005 on page http://www.jetcatusa.com/Accessories%20Catalog.pdf
You can probably buy direct from a supplier such as Festo if you want, but you would need to either search through their catalog or call 'em up and ask them to identify the correct QS* part number for you (I've done both in the past).
Gordon
Old 08-18-2010, 04:38 PM
smitty1001
My Feedback: (29)
smitty1001's Avatar
IIRC, part A-1005 is actually a 4mm connector, Jetcat propane installs go to 3mm via a reducer closer to the motor i think
Old 08-18-2010, 04:40 PM
Gordon Mc
Sorry - you're right - my bad on that one - it's 4mm on the Jetcat page. I'm sure I've had some smaller versions in the past - either 3mm or 1/8" - might have to check with Festo / SMC.
Gordon
Old 08-18-2010, 04:53 PM
smitty1001
My Feedback: (29)
smitty1001's Avatar
no worries! thanks for all your help, I think i'll use tam's (robart?) one-way disconnects unless someone comes out of the woodwork with a festo 3mm. Couldn't find such a thing on their site or SMC's.
My next quest will be for a dual digital air pressure gauge like todd's but packaged much smaller!
Old 08-18-2010, 05:12 PM
DelGatoGrande
My Feedback: (23)
bvm or festo at the end of the day you will need a valve and it the same think
http://www.rcuniverse.com/forum/m_89...tm.htm#8938541
Old 08-18-2010, 06:04 PM
Gordon Mc
My next quest will be for a dual digital air pressure gauge like todd's but packaged much smaller! [img][/img]
The smallest digital pressure gauges I've seen & used, were sold for a while by CJM. CJM no longer has 'em, but Sandor (Digitech here on RCU) stocked them recently - you might want to have a look at those.
Gordon
Old 08-18-2010, 06:06 PM
Gordon Mc
PS - here's another style of check valve that you could perhaps use instead of the Festo style : http://www.specialtymfg.com/check_va...es/default.asp
Old 08-18-2010, 06:43 PM
ianober
My Feedback: (12)
ianober's Avatar
Not sure if it fits your size requirements Smitty but this might do:
[link]http://www.airpowernet.com/twe3/product_info.php?products_id=342[/link]
Old 08-18-2010, 07:09 PM
smitty1001
My Feedback: (29)
smitty1001's Avatar
Thanks Ian, that IS todd's. (just branded for dreamworks) Iwill probably go with that one - just wanted to test the waters and see if there was anything smaller. I wonder if the case could be removed on the Airpower/DW one and shrink wrap the board?
Looking for a link to Sandor's site.... EDIT: http://shop.jet-1a.com/ (he must not be carrying a digi pressure gauge these days)
Great find on the SMC Gordon! Thanks!
Old 08-18-2010, 07:41 PM
Gordon Mc
I'm not sure where to find themn on his site, but here's where he posted about them : http://www.rcuniverse.com/forum/fb.asp?m=9294158
Might be worth dropping him a PM / email if you are interested. The face of these gauges is about the size of a dime.
