RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Titan DeRated thrust.. (https://www.rcuniverse.com/forum/rc-jets-120/10019273-titan-derated-thrust.html)
Pete737 09-22-2010 07:15 AM
Would anyone happen to know the thrust output on a non-se Titan which has been derated to 122k?
Thanks, Pete
quist 09-22-2010 09:37 AM
RE: Titan DeRated thrust..
You can always boost it back up to 123k. Then it is 34lbs.
Meesh 09-22-2010 09:41 AM
Pete
This is the 160SX should be similar?? or is the Titan the 180?
P160-SX Thrust Chart
RPM Thrust
32,000 1.0
100,000 19.0
105,000 22.0
115,000 28.5
120,000 31.8
123,000 34.0
125,000 36.0
Bob
Pete737 09-22-2010 09:49 AM
Hey thanks guys, Bob thanks for the chart. The Titan is a 160 size so it would probably be safe to assume approx. 32-33 lbs at 122k.
Thanks again, Pete
KC36330 09-22-2010 03:38 PM
1 Attachment(s)
non SE is the same as the SE as far as thrust at XXX RPM............
