Setting up brakes for AIRPOWER EV5U
been searching the web on how to set up the brakes for the Airpower EV5U multi action valve.
this is the basic EV5U, the older version which u need to set up with the programming card. Not the new digital version. Problem is with the brakes. I am using the aux channel to operate the brakes. The aux channel is assigned to the elevator stick so that i can activate the brakes when i push the elevator stick. I managed to put it in the anti lock mode but am unable to find out how to set the low and high points to activate the brakes. I think it is now in default position meaning that when i have pull the elevator full down the brakes is off. With the stcik in the MID neutral position, it pulsing in antilock and with the stick in the full up position it is full brakes ON. Is it possible to set this valve such that when i am in mid stick, brakes is off, and full up is brakes FULL ON. I know with a jettronic vlave i can do it by setting the activation points. been searching and scratching my head on this. thanks |
