Ram ECU needed
Looking for someone that has a spare ECU they would like to sell. Need a working condition Airstart ECU for a Ram 750/1000.
RE: Ram ECU needed
TTT
RE: Ram ECU needed
Are you looking for the original Electrodynamics ECU that used CP in put ?????
RE: Ram ECU needed
Why not just change over to a more reliable, better engineered, well proven ECU? http://www.xicoy.com/catalog/index.php?cPath=22_24
RE: Ram ECU needed
Yes looking for a Electrodynamics ECU that uses CP input. Would be willing to convert to electric start if I could find one for it.
RE: Ram ECU needed
ORIGINAL: mtspawn Yes looking for a Electrodynamics ECU that uses CP input. Would be willing to convert to electric start if I could find one for it. I got one...Don't know what it's worth... Make me an offer.... Danno |
RE: Ram ECU needed
ORIGINAL: lov2flyrc Why not just change over to a more reliable, better engineered, well proven ECU? http://www.xicoy.com/catalog/index.php?cPath=22_24 yea..this is the way to go....and you can use these ECUS on other engines as well. jet joe has electric starters that will fit the aluminum ram covers. I have the fadec from xicoy...wish I had some more. |
RE: Ram ECU needed
Send me a pic of your turbine front, I have a starter+front cover+spinner nut for sale that may fit, remember that to use the xicoy ECU with RPM pickup you have to have a magnetic spinner nut, I have one of the flat ones that will fit the starter I have...
| All times are GMT -8. The time now is 11:41 AM. |
