Wing Tubes
1 Attachment(s)
Hi all, looking for 2 things, info on how wing tubes are standing up to their job, personal experience , would be good.
Secondly, a supplier of 2mm, 30mm dia. Aluminum tubing. When I look at a Comp. Arf Lighting, I like their 40mm. tubing, going 13' into the wing, looks good. What I don"t like is a Jet that is twice the weight, using 30mm/1mm alum. tubing, going only 8' into the wing. I will try to find a supplier, selling 2mm. thick wall, plus I'll get a longer tube. What do you guys think, I'm being too cautious Rcpete |
RE: Wing Tubes
Rcpete, I use this aluminum for my Jetmach kits. The tube goes 18"' into each wing.
http://www.texastowers.com/aluminum_.htm FYI, each tube size will fit inside the other bob |
RE: Wing Tubes
1 Attachment(s)
Pete,
I get all my Aluminum Tube from Aircraft Spruce and Specialty. I make my wing sockets from 2" fiberglass tape wrapped over the tube with a wax paper barrier between the glass and the tube. West System resin brushed on and I get the exact tube and socket I need. Ron |
RE: Wing Tubes
Try www.tntlandinggear.com, they have a nice selection of T6 Alu and Composite wing tubes with and without sockets.
RE: Wing Tubes
I forgot to say that my method is very inexpensive.
RE: Wing Tubes
Hey Pete,
Merry Christmas. I have used this Co. for Aluminum Tube. http://www.aircraftspruce.com/ Joe Lewis |
RE: Wing Tubes
HI joe, these guys are great, to bad they don"t sell metric, as most of our jets are metric.
Rcpete |
RE: Wing Tubes
Hi L Turner, are you sure the spelling is correct for the link.
Rcpete |
RE: Wing Tubes
HI Ron, your method sounds great for future projects.
Right now, I need a metric==================- Aluminum=============== tube replacement. Thanks Rcpete |
RE: Wing Tubes
I just bought some CF tubes for the HotSpot here
http://www.s271082832.e-shop.info/sh...aid%3D03959%26 |
RE: Wing Tubes
Wall thickness dos'nt mean it will be better, the spec of the tube is what you want, a thin walled 6061 or 6082 is much better than a lower spec with a thick wall.
6061 and 6082 are used to build ultralight's, another way of increasing the strength again used a lot in ultralights is to fit one tube inside the other. Two light, thin walled tubes here will be extremly strong. |
RE: Wing Tubes
Pete,
I ordered a replacement tube for the ME 262 we're building (from the 1/4 scale French kit - the wing tubing came up missing) from Parker Steel: http://www.metricmetal.com/products/rdalum_tube.htm Its 6061 tubing and they have it in various sizes and wall thicknesses - all in metric only... Bob |
RE: Wing Tubes
Thanks Bob, that"s exactly what I been looking for.
Rcpete |
| All times are GMT -8. The time now is 12:11 PM. |
