RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   The reason JetCat's are boring (https://www.rcuniverse.com/forum/rc-jets-120/10308996-reason-jetcats-boring.html)
BaldEagel 02-03-2011 05:33 AM
1 Attachment(s)
The delivery of my P20 from Ali was next day within the time hour specified, Put the P20 on a rig, attached the Rx, Learn RC came up on the GSU, did what I was instructed by the GSU, fueled up throttled up and it started, what impressed my the most was the spool up time, from 85,000 to 245,000 took about 3.5secs, not scientific, just a count on my watch.
Mike
Ali 02-03-2011 05:42 AM
RE: The reason JetCat's are boring
Kero start as well... :eek: I know what you mean about the boring thing though. I almost miss the days of failed starts, flames chucking out the pipe and fire extinguishers at the ready.
Nice one Mike! Have fun with it.
Regards Al
Couch Potato 02-03-2011 05:43 AM
How can it be boring with that oil rig sticking out the side of the can ! :D
BaldEagel 02-03-2011 05:47 AM
Ali
Its just so easy to change to Kero start, push two buttons whilst powering up the Rx and that's it done, changed from Gas to Kero.
Can't wait to get the Habu, but I suppose I will have to, meanwhile I will have to look at what I have alredy that I can put it in, I think the Spear is to small, have to search through the loft.
Mike
BaldEagel 02-03-2011 05:49 AM
ORIGINAL: Couch Potato
Must admit the standard Kero plug does look out of place on such a small turbine, but better than the alternative. ;) Just have to wait for the delivery of the low profile Kero plug.
Mike
AFTERBURNER1 02-03-2011 05:53 AM
ORIGINAL: Ali
There are still some that will do that for you!!!:D
Couch Potato 02-03-2011 05:59 AM
What's the spec on the ECU LiPO, how many mAh consumed on a start ?
Have you asked Jetcat about A123 ECU modification yet ? (although size of a 3S A123 would be a problem in a small airframe)
BaldEagel 02-03-2011 06:07 AM
I used an ECU LiPo from my P120SX to run the start, unfortunatly this was partially discharged so I am unable to determine the Mah used, as far as I know (not from JetCat) all the equipment bar the pump can take the voltage from a 3S A123, so unless we can rig something to bring the voltage down on the pump its a no go, a 3S A123 1100Mah is small enough to use in any airframe, if constructed end too end it would fit right up into the nose of any airframe.
Mike
BaldEagel 02-03-2011 10:17 AM
It would be good to know from JetCat if a three cell A123 could be used with the P20?
Mike
John Casey 02-03-2011 10:26 AM
Your right.... the autostart ECUed turbine has
made it possible for ......... "Anyone"....... to be able to start a turbine.
Not that long ago in order to be a jet pilot you had to have..... SKILLS.
Skills beyound that of mortal modelers, the capability to handle fuel, air, propane, and a fire bottle....all at once, true multi-tasking.
It was a job for the young, foolish, pilots we once were.
Now we pretty much.......... push the button
and watch what used to be money .....traded in for fuel.... burn.
3dean 02-03-2011 10:37 AM
ORIGINAL: airkiller
made it possible for ......... ''Anyone''....... to be able to start a turbine.
Now we pretty much.......... push the button and watch what .....used to be money .....transformed to fuel.... burn.
wow dude , glass half empty is it !
BaldEagel 02-03-2011 10:42 AM
With Kero start the Gas bottle is empty thank G*d, but the experience of starting on Kero is without doubt a glass 9/10ths full, will never go back to Gas start.
Mike
John Casey 02-03-2011 10:45 AM
I filled up my kero glass early this year..... no worries... love the kero starts too,
I'm looking forward to NOT dragging a propane bottle to the field.. someday.
Ali 02-03-2011 10:48 AM
Hi Mike, I am with you on the Gas start!
Direct from JetCat
the P20SE- ECU is no problem, but the P20SE- fuel pump is only for max. 10V, not more!!
You can don’t use 3 cells A123, 2 cells A123 is to low.
You can use only 2s- Lipo battery.
Regards Al
BaldEagel 02-03-2011 10:54 AM
Ali
I rearly want to get rid of LiPo's from my on board equipment and have lots of A123's to use, both 2300Mah and 1100Mah, have you any idea what sort of shunt I need to put in the supply line to the pump to regulate the voltage down to 6 volts?
I am sure I am not alone in this.
Mike
Selleri 02-03-2011 05:01 PM
Couldn't you just use a voltage regulator inline with the pump Mike? Plenty of them around that can do these numbers.
i3dm 02-03-2011 05:15 PM
ORIGINAL: Ali
Direct from JetCat
Regards Al
A123 three cell pack is 9.9V nominal.
BaldEagel 02-04-2011 01:18 AM
ORIGINAL: i3dm
But come off the charger at over 11 volts.
There are four wires into the pump which one's do I regulate? I suppose I will have to put a volt meter on them to find out, just seems a shame that JetCat did not realise that a lot of people use A123's.
Mike
mick15 02-04-2011 02:23 AM
I don't understand why you would need to regulate the pump voltage, that's what the ecu does. The pump voltage is never going to get anywhere near 9v.
m
BaldEagel 02-04-2011 04:08 AM
I think its because maximum volts to the pump at full throttle is the ECU battery voltage.
Mike
mick15 02-04-2011 04:24 AM
No it's not. If the pump receives more tha 4 volts I would be very surprised.
m
BaldEagel 02-04-2011 04:28 AM
On second thoughts the Pump voltage is possible controled in the same manner as an ESC controls an electric motor in which case it sees the ECU voltage the whole time and is switched on and off to control the speed of the pump, this is suposition on my part and I am only quoting the information I have received. i.e. the pump can not take over 10 volts.
Mike
i3dm 02-04-2011 04:38 AM
a three cell A123 pack will only stay above 10V for a short period of time, and then go down to constant nominal 9.9V anyways.
BaldEagel 02-04-2011 04:57 AM
ORIGINAL: i3dm
Agreed, If you have a P20 and some A123's please try it out and let us know if the pump is still OK. ;)
Mike
mick15 02-04-2011 05:03 AM
Not so Mike, check the voltages on your existing Jetcat, U excl 1 is 0.25v and the max pump volt is usually 3.5v ish. don't forget, it is not a brushless motor.
m
