RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Flap problem........ (https://www.rcuniverse.com/forum/rc-jets-120/10375428-flap-problem.html)
A MAY 03-02-2011 06:06 PM
HI!
Getting very frustrated, setting up the flaps on the yellow f-15 have a matchbox ,jr 12 x, setting up the travel etc, ok in the full up position but on the full flaps down one side goes down more than the other by about 1/8 in. more whats up that i am not doing to get it even on both sides on the down side thanks
Arden
S_Ellzey 03-02-2011 06:17 PM
RE: Flap problem........
Choose the flap that looks right and then adjust the other. Set the flap to the midpoint, watch the led on the matchbox and it will tell you when you are there. Now adjust the other flap with the matchbox to match the throw on the other side. Go to full down and adjust it to match full throw, then repeat for full up. it is important to match the mid point first. Make sure to set the matchbox dial back to "0" before you power off. That should do it.
Steven
A MAY 03-02-2011 07:15 PM
Steven
thank-you the problem is solved and is ajusted perfectly, now my batteries went dead no problem they will charge.
THANKS AGIAN
Arden
