3M Dp-420 epoxy???
I got some of this 3M Scotch-Weld eposy adhesive (DP-420) from work and was wondering if anyone has used this stuff or knows anything about this stuff. If its ok to use or not. :rolleyes:
Thanks for the info David |
3M Dp-420 epoxy???
the 420 is the high strentgh right? I played with the 3m stuff and floated a few over to a friend who had the hysol aeropoxy stuff. the 3m is pretty good stuff. he still like the hysol better. If you have it though, I wouldn't be afraid to use it. You can pull the specs on it down from the 3m website and compare it to the hysol product. If i remember correctly the 3m is readily available from grainger.
3M Dp-420 epoxy???
I use 3M 2216 it sets not brittle and will barely run on vertical.
Darryl Usher |
| All times are GMT -8. The time now is 06:50 PM. |
