CALLING ALL FLASH EXPERTS!
Flash Experts, I have a issue/question....
For a friend I am installing a TAM's pipe in his Flash. I was given the jet and the pipe....so me has questions! How is this installed, exactly? Do I retain the original Flash outer pipe and slide the Tam Pipe inside? It seems like this is the ticket, however the pipe is not "snug" at the back end and can actually move up/down/right/left about a 1/16th of an inch. Not sure how to proceed without fabricating new bulkheads and removing the original outer flash pipe. Can anyone shed some light?[8D] |
RE: CALLING ALL FLASH EXPERTS!
Dave: No problem...just slide it in and run in a couple of dry wall screws.
:D Mike |
Dave,
Dry wall screws sounds good. I am sure you use them every day at work.;) George |
not sure what that particular Tams pipe looks like, but there should be some spacer tabs at the back....the pipe will expand with the heat from the running turbine, so that would probably take care of any looseness.....
You do not need the outer pipe and the 1/16 movement is not a problem. I have a Tam pipe in my Ultra Flash and it works fine. The only challenge is balancing the plane. Since the Tam pipe is lighter, you may need to move your batteries back. I have my smoke pump and 4 batteries under the cockpit area for balance.
ORIGINAL: dubd You do not need the outer pipe and the 1/16 movement is not a problem. I have a Tam pipe in my Ultra Flash and it works fine. The only challenge is balancing the plane. Since the Tam pipe is lighter, you may need to move your batteries back. I have my smoke pump and 4 batteries under the cockpit area for balance. I await additional input from other Tam Pipe users. I would install the drywall screws as suggested but the owner would frown upon them most vigorously! |
Dubd, you DO NOT have any of the original pipe installed on your Flash?
ORIGINAL: InboundLZ ORIGINAL: dubd You do not need the outer pipe and the 1/16 movement is not a problem. I have a Tam pipe in my Ultra Flash and it works fine. The only challenge is balancing the plane. Since the Tam pipe is lighter, you may need to move your batteries back. I have my smoke pump and 4 batteries under the cockpit area for balance. I await additional input from other Tam Pipe users. I would install the drywall screws as suggested but the owner would frown upon them most vigorously! I just double checked and I did have about 1/8 movement between the pipe and fuse, but I installed spacers to stop the movement. Even without the spacers, there was less movement than what I eventually would get with the stock pipe in my classic Flash. The benefit of the Tam pipe is that it is lighter. My plane weighs less than 21lbs with a 160SX, 48 oz smoke tanks, and three 2s 2200 batteries (rx & ECU) and one 2s 1300 mah (smoke). The Tam pipe isn't necessary, but I didn't have to use big batteries to balance the plane. With my classic Flash I needed to install the smoke pump in the nose and use 2s 3300 mah batteries to balance the plane. The Tam pipe doesn't require any more effort to install than the stock pipe. In fact, it's easier since it is a single piece. |
I have a Tams pipe in my flash and just glued in 4 small hardwood blocks in the tail to shim the pipe in proper position. I did taper them a bit to provide better contact with the pipe but that is all that i did. The Flash has over 100 flights on it and the pipe is still right where it belongs.
I did as Sailing1 did, on the rear former used wood blocks to help support and center the tailpipe. It's a very easy and clean setup, was impressed with the pipe.
Tam's pipe is an improvement on the stock pipe in weight, construction, efficiency, quality, etc. CARF states that the stock pipe is a compromise in the manual.
I will look at it again, frankly as I have said before I dont see the point but that man wants what he wants....
I personally found it a simpler install than the factory unit. Just bolt the carbon bellmouth to the Tam's pipe ( mine had predrilled holes in the pipe with 2 retaining straps ), mount the bellmouth to the former as per manual with the supplied "L" brackets and then use some wood blocks attached to the rear former that center the pipe in the tail cone. The outer part of the pipe is almost flush with the tail cone. I was really impressed with the fit actually.
My dry weight was almost a pound less with Tam's pipe. That was worth it to me.
ORIGINAL: dubd My dry weight was almost a pound less with Tam's pipe. That was worth it to me. I have the new pipe installed using the hard wood space method as described above. It is a very nice pipe, no question. If my flash ever needs a new pipe this is the one I am going with! Tomorrow, I re-balance the jet. |
I think he meant all up weight, 4oz in the tail probably needs 12oz up front to balance.
Kevin |
1 Attachment(s)
Well where are the PICTURES
The problem is, Dave used 8oz. of hardwood to install the pipe, so my net was 4oz gained! :D
Thanks for the great work as usual Dave. Tam, that pipe is rock solid and the difference in quality is easily apparent. The weight savings on this pipe is really secondary to the difference in quality. Chad |
Yep, 4oz off the tail means less weight in the nose like I mentioned earlier.
Can someone please tell me what the Tam pipe weighs? (contemplating a pipe upgrade) Thanx
ORIGINAL: myersflyers Can someone please tell me what the Tam pipe weighs? (contemplating a pipe upgrade) Thanx |
Botitta, just make the pipe bigger to take up the slop and drop the 180 in there....I'll be in LAS tmrw to bust a few laps on it. :D
Had a few problems with the flash yesterday. I had programmed in crow with full flaps, when activated it pulled toward the canopy a lot and took a lot of down elevator to keep level. I have 45mm of flap and 5mm of aileron deflection ( crow ). As the planed slowed the tail naturally started to settle and exagerated to issue. Am I not using enough crow? I know on another Flash without crow I started out with the recommended 65mm flap but reduced it to eleviate the touchiness of the elevators.
The cg felt really good and flew fantastic other than this. Has anyone ever tried reflexing the ailerons "down" instead of up ? |
I have some down elevator programed in with my Crow.
I don't know how much off hand. What I did was after every Landing I kept adding a bit of down elevator in the program until I was happy with how the plane was handling when I was landing. C.G will also change that as well. Mine is balanced at the 370mm mark |
10mm CROW is normal for us (flap/aileron joint) 1mm of down elevator, balance 365mm. Flap is atround 40-45mm. The model sits nose high on the approach, that was the idea of the CROW to add aerodynamic drag (like Concord :D) I only switch to the full flap/CROW position around 200m/yards out on the run in.
Dave |
Thanks Dave, that was the concensus that I had too little crow. Will back off on the flap a little and up the crow, I had it go in the same time but will put the crow on a seperate switch so I can negate if needed.
Have you or anyone you know tried reflexing the ailerons down instead of crow, I know the wing makes a ton of lift and will fly dog slow anyway but was just a thought, may not have some of the tendencies. |
ORIGINAL: ddlstang Have you or anyone you know tried reflexing the ailerons down instead of crow, I know the wing makes a ton of lift and will fly dog slow anyway but was just a thought, may not have some of the tendencies. With crow, there is essentially more stall protection for the outer wing section and the jet's body angle and drag is a little higher on approach. The approach speed is slightly higher. The thrust on approach as to be a little higher due to the drag. But when you chop the throttle the model bleeds energy much better and makes predictable touchdowns and seems to stick to the runway nicer and handle better in the deceleration. I was using less runway consistently with crow and was working less on approach; a win-win for me. Plus a faster approach speed is typically ideal for any sort of wind or gust conditions as the flight controls tend to be more effective at the slightly higher approach speed. Higher approach thrust bodes well for spool up of course. A little reflex is good and a lot of reflex is NOT better, it's bad. Each wing will behave differently but it seems this model is pretty well tested on reflex values. And I know of a few guys who still like drooped ailerons; we've discussed the merits of both but... I'm sold on crow all the way, it's no contest for me. |
Dale
I have the CROW come in with landing flap. Eddie just about said it as it is! Every aeroplane is different and the CF with the tip tanks/shape might cope with the droop, but the model works well with the CROW set up. Dave |
The stock CARF pipe can take a beating. Royally.
And when you have to keep up with Dougie and DA boyz, you have to spank your big block infused flash. Raf |
By the way; does anuone has a thunderbirds scheme elevator that would be willing to sell?
If yes, please contact me at [email protected] Thanks; E.N.T. |
| All times are GMT -8. The time now is 07:14 PM. |
