RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Help... (https://www.rcuniverse.com/forum/rc-jets-120/10495113-help.html)
Shaun Evans 05-01-2011 01:32 PM
Help...
Hey,
What's your favorite method for de-warping balsa wood? Actually, to be more specific, it's balsa-sheeted foam. The temp changes around here got to a couple of ailerons and now they're bowed. I tried setting some weight on them, but no change. I can't be the first guy....
Countryboy 05-01-2011 02:01 PM
RE: Help...
You can try a 50/50 mix of ammonia & water. Wet out the side opposite the warp and weight the ends down while supporting the middle. What you want is to actually overweight the ends so as to create a slight bow opposite of the bow that is there now. Leave & let dry, remove the weight and see what you have. Short of cutting into the aileron, this is about the only option.
ddlstang 05-01-2011 03:00 PM
RE: Help...
ditto
