RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Emcotec DPSI BMS power switch... (https://www.rcuniverse.com/forum/rc-jets-120/10518939-emcotec-dpsi-bms-power-switch.html)
Countryboy 05-14-2011 02:41 AM
Just switched my Jr 10x over to Fasst. I will be using the Futaba R6014 receiver with an Orbit Powerjack and I am thinking of using the Emcotec DPSI BMS 2 Channel power switch. Anyone have field experience with this switch. I will be using twin Electrodynamics A123 2300mah packs.
http://dreamworksrc.com/catalog/index.php?cPath=59_109
FenderBean 05-14-2011 03:49 AM
RE: Emcotec DPSI BMS power switch...
why sp fancy of a switch why not just the one at bottom, powerbox smart switch?
Countryboy 05-14-2011 03:57 AM
It would take two switches and the Emcotec is better suited for the connector/ wiring arrangement for the Orbit Powerjack.
FenderBean 05-14-2011 04:01 AM
yeah sorry I was just looking at that, yeah im going to run the power jack on my 14 channel receiver as well. after looking I would like to try it myself, no need for any kind of major power system with the orbit and you can just plug two duralite IONS right into it.
thanks bro you just helped me decide something :)
Countryboy 05-14-2011 04:12 AM
A little more info offered here... http://shop.rc-electronic.com/downlo...ung_V10_EN.pdf
Don't forget to order the accessory package, as it doesn't look like the cables are included with the switch.
FenderBean 05-14-2011 04:23 AM
I have been looking at emcotec stuff, german guys usually make good stuff, what size jet is this for? mines 1/6 scale f-16 I am still trying decide on a battery to run for my receiver. I cant decide on Ions like my giant or maybe just try A123s for the 1st time.
Countryboy 05-14-2011 05:07 AM
Jet Legend F-4... thread at http://www.rcuniverse.com/forum/m_92...tm.htm#9309455
ZivBit 05-14-2011 05:29 AM
Guys
This is not a switch, but a batery monitoring system. It shows the bat. voltage, min\max voltage during flight, etc.
Not an on\off switch.
Cheers,
Ziv
Countryboy 05-14-2011 06:00 AM
Thanks for turning on the light. After reading into it more, I now see you are correct.
siclick33 05-14-2011 06:13 AM
There is a switch version called the BIC.
http://shop.rc-electronic.com/e-vend...&t=6&c=15&p=15
ZivBit 05-14-2011 07:54 AM
Sorry but NO.
The BIC still requries an external switch to operate as an on\off switch.
Simply read the manual.
Ziv
swissflyer 05-14-2011 08:12 AM
for small jets the BIC is the perfect double battery controlled, regulated output and all the important informations like current and voltages and battery (mAh) used..
and is one battery is dead or not connected..it makes sure you ear it!!! ;)
and no, there is no need of external switch on the BIC...you can add it, but is not mandatory ;)
in the last version, the come completes with the wiring BIC-RX included and spare battery plugs
siclick33 05-14-2011 08:33 AM
ZivBit, Sorry but YES:D
From the website:
Dual battery supply system with electronically on/off-switch and constantly regulated output voltage (5.9V).
An optional external switch allows for applications where no direct access to the pushbuttons of the DPSI BIC is possible.
JohnMac 05-14-2011 08:49 AM
I use the BIC system on all my jets. Brilliant system. They also do an excellent active (programmable ) Y lead.
ZivBit 05-14-2011 08:54 AM
ORIGINAL: siclick33
From the website:
I guess you are right on the BIC...
I have the old version one (BMS)
Good luck with it.
BTW - Boomarc.com have some great new switches with LCD monitors in them. Have a look here. I use one in my jet and its great.
Cheers,
Ziv
HarryC 05-14-2011 09:44 AM
I use the BIC in my jets, I have a BMS to use with another jet that already has much of the BIC stuff built into the Rx. The BIC is a switch in itself, the external switch is just an option. The BIC is superb.
ORIGINAL: ZivBit
BIC and BMS are different things, not an old and a new version of the same thing. BIC is a switch with a regulator, two battery inputs but one output albeit with a twin lead. Thus in the BIC there is a commoning of the circuit. A 2-channel BMS has two totally separate circuits with no electrical common between them, so two inputs and two outputs, no switch, no regulator. I will be using one BMS channel to monitor the main battery input into the rx that has its own regulator and redundancy arrangement, and the other BMS channel to monitor the reheat LED lipo.
ORIGINAL: JohnMac
I had that in my small F-4 John, it's an excellent device.
I really like Emcotec stuff.
Countryboy 05-14-2011 12:36 PM
Thanks for the info guys. I guess what threw me on the BMS is that it was listed in the switch section on the Dreamworks site and I did not read the info properly. The BIC seems to offer all the bells & whistles of the BMS and still perform the power supply function. Sadly, Dreamworks does not seem to offer the BIC... at least its not listed.
madmodelman 09-21-2011 03:25 AM
John, do you still use a p/box with the bic switch?
Regards,
Gary.
martin_wam 09-22-2011 06:36 AM
<span style="font-size: small; "><span style="font-family: Arial; ">Ziv, the switch fromBoomarc.com is awesome - exactly was I was looking for to use with Orbit Powerjack.
Any European vendors?</span></span>
Mavpro 09-24-2011 12:59 PM
ORIGINAL: Countryboy
I use it in my Sebart SU 29 2,6 along with Powerbox LiPo batteries. Works fine for me.
