RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Looking for brakes? (https://www.rcuniverse.com/forum/rc-jets-120/10586303-looking-brakes.html)
kelly vallee 06-22-2011 01:47 AM
Looking for brakes?
I have tried many brakes, from gleeson, trim and behotec, and still have not found a set of brake that real stop my plane. I see people in jet rally's and there plane stop good, is it because I lub up to much the hub or what? Is the a real set of brake, like the caliper on a car out there? Any help please. I'm using a Jetcat brake valve with 100 psi.
RAPPTOR 06-22-2011 02:37 AM
RE: Looking for brakes?
BVM
lov2flyrc 06-23-2011 05:02 AM
What plane? What size wheel?
rcguy! 06-23-2011 08:27 AM
I thought you didn't lube up TRIM brakes?
Dave
John Casey 06-23-2011 10:31 AM
What are you useing for lube?
Are you actually looking to come to a stop....like on a dime?
kelly vallee 06-23-2011 03:21 PM
I'm looking for 3" main, and I would to stop on a dime, but ten feet is OK. On my Behotec, I'm using SuperLube on the rubber.
lov2flyrc 06-23-2011 05:04 PM
ORIGINAL: kelly vallee
There's the issue.... NEVER.... NEVER use anything but a O-ring lubricant and when you do, use it as sparingly as possible. less than a BB sized amount of lube and wipe off as much of it as you can with you finger. Clean the bands and hub with denatured alcohol and lube with Parker O-Ring lube or similar.
